by jpark - February 24th, 2010, 8:53 am
There is no ground on the headlamp plug on a 2001-2004 Escape. I also said that the resistor will only get hot when the high beams are on. My guess is that you have it connected as I described it above, but if you can post a picture, I'm sure that it would help anyone else who wants to do this.
Again, the 2001-2004 Escape has no ground on the headlamps. The fog lamp relay is wired in series with the high beam filaments, and the common pin to each headlamp filament goes to +12V through the main headlamp relay.
"Ford has been improving steadily and has twelve models in the top three in their categories this year,
more than any maker." - J.D. Power
2010 Ford Escape Limited FWD, Black, Camel heated leather, new 4/22/2010
- 2.5L 4, 6-speed auto, Sync, navigation, rear camera, and all factory options except active park and step bars
- Curt 12060 Class 2 hitch, SportWing ChromeLine moldings, H13 SilverStar headlamps, factory splash guards
2008 Ford Fusion SE FWD, Black, Charcoal/Red leather, new 2/23/2008
- 2.3L 4, 5-speed auto, Sync, and Sport Appearance, Moon 'N Tune, and Ambient Lighting packages
2007 Ford Edge SEL Plus AWD, Blazing Copper Metallic, Charcoal Leather, new 6/18/2007, sold 4/22/2010
2005 Ford Escape Limited 4WD, Redfire Metallic, Pebble Leather, new 6/4/2004, sold 6/18/2007
