Wiring for backup camera
Postby Sternig - February 19th, 2010, 11:45 am
Hi
I have a 2010 Mercury Mariner and want to add a backup camera. I have a old wireless camera that mounts on the licence plate and requires 12 v when in reverse and ground. Since the Mariner has a factory option for a camera I thought I'd ask if anyone knows if the tailgate already has the wiring before I run the wire up and over to the backup lamp.
Sternig
Re: Wiring for backup camera
Postby jpark - February 19th, 2010, 12:44 pm
I'm trying to get a 2010 service DVD, so I'll have an answer for you when I have one.
My guess is that the 2010 backup camera module replaces the 2008-2009 liftgate switch, which was relocated for 2010 to a new handle under the license plate.
2016 Ford Escape Titanium 4WD, Magnetic Metallic, Charcoal Heated Leather, new 9/23/2015
- 2.0L EcoBoost I4, 6-speed auto, 301A, Sync 3/Sirius/HD, Panoramic Roof, Navigation
- Husky WeatherBeater 99741/23741 mats, Ford factory splash guards
2008 Ford Fusion SE FWD, Black, Charcoal/Red leather, new 2/23/2008, still strong and trouble-free
- 2.3L I4, 5-speed auto, Sync, Sport Appearance/Moon 'N Tune/Ambient Lighting packages, Husky WB 98301 mats
2013 Ford Escape Titanium 4WD, Ruby Red Metallic, Charcoal Leather, new 11/2/2012, sold 9/23/2015
2010 Ford Escape Limited FWD, Black, Camel Leather, new 4/22/2010, sold 11/2/2012
2007 Ford Edge SEL Plus AWD, Blazing Copper Metallic, Charcoal Leather, new 6/18/2007, sold 4/22/2010
2005 Ford Escape Limited 4WD, Redfire Metallic, Pebble Leather, new 6/4/2004, sold 6/18/2007
jpark
E-C Administrator
My nickname: JP
My vehicle: 2016 Escape Titanium 2.0EB 4WD
Postby Katscan - June 16th, 2010, 5:51 pm
:bump:
So what was the verdict on this? Im looking to install a backup cam as well as it will make parking here in Germany a lot easier with one.
Katscan
E-C LEVEL 3
My vehicle: 2010 Ford Escape XLT
My vehicle's name: Tatsu
Postby Creaky - June 17th, 2010, 6:31 pm
If the wiring is already installed, you should be able to find harness 14A583, connector C4234, found in the center of the liftgate below the window (the camera itself would be mounted in the license plate housing).
Pinouts for connector C4234 are as follows:
1 - * (WH) 18 FUSE - 35 OR CIRCUIT BREAKER
2 - DMP19 (NONE) 18 DRAIN
3 - * * Not Used
4 - * (RD) 20 VIDIO+
5 - * (BK) 20 VIDIO-
6 - * (BN-RD) 20 GROUND - LIFTGATE/DECKLID CENTER
7 - * * Not Used
8 - * * Not Used
Creaky
E-C LEVEL 1
My vehicle: 2009 Mariner 6 Cyl 4WD
Postby Katscan - June 18th, 2010, 12:50 am
Do they install this on every Escape? I have an XLT
Katscan
E-C LEVEL 3
Postby jpark - June 22nd, 2010, 9:53 am
The service DVDs don't mention any differences in harness part numbers, so the easiest way to find out if you have the connector for the rear view camera is to remove the inner liftgate trim panel. The connector is located between the license plate lamp connectors:
Direct image link: http://i246.photobucket.com/albums/gg10 ... ftgate.jpg
Here's the wiring diagram for E/M/Ts equipped with a factory rear view camera:
Direct image link: http://i246.photobucket.com/albums/gg10 ... wiring.jpg
If you do have the rear view camera connector in the liftgate, check the connector inside the lower area of the driver-side (left) A-Pillar:
Direct image link: http://i246.photobucket.com/albums/gg10 ... 10C214.jpg
If you find a WHITE with GREEN STRIPE wire (VIDEO +) and a BROWN with VIOLET STRIPE wire (VIDEO -) at pins 15 and 16 on that connector, you can tap into those wires for the video feed if you connect the factory rear view camera.
jpark
E-C Administrator
My nickname: JP
Postby Katscan - June 22nd, 2010, 10:11 am
Ok, Im a bit confused here. So if I had purchased an aftermarket backup camera, I could wire it into the video + and video - to give the aftermarket camera power so it would turn on when put into reverse?
Also in the same token, is there a way to buy the factory backup camera and rearview mirror (with integrated display) from Ford? They dont list it as an accessory that I can see. I wanted one but they only came with the Limited....sometimes I hate it when they do that.
Katscan
E-C LEVEL 3
Postby jpark - June 22nd, 2010, 10:41 am
Ford's wiring has power to the mirror whenever the key is in RUN or START. The circuit in the inside mirror (or navigation screen) uses the reverse lamp feed (+12V when on) to display the video from the camera.
From what I remember, that mirror is very expensive from the factory, although it's also available in the aftermarket (Gentex 50-GENK242) for around US$340. There's also a 50-GENK352 with a larger screen, and a larger price tag. You could also buy the factory rear view camera, but you'd need to have the factory wiring harnesses if you don't want to run your own wiring.
jpark
E-C Administrator
My nickname: JP
Postby Katscan - June 22nd, 2010, 11:43 am
Sorry, hehe I guess I didnt ask the correct question lol :doh:
Ok, I already purchased an aftermarket wireless backup camera and I need to wire the camera into the reverse light so it will get power when I put the car into reverse. Does the wiring harness(if I have it) provide power to the camera only when the vehicle is put into reverse? In other words could I wire up my aftermarket camera into the video + and video - to get the camera power for reverse? or do I still have to run wires up along one of the pillars to the reverse light?
EDIT
:rant: Ok well.....hit a snag :cuss:
Seems the license plate holder/backup cam frame is too small for the license plate :cuss: :censor: :cuss: I mean....wtf....how can they sell me a freekin device that I cant use? I tried every which way to get the license plate into the holder but it wont fit :rant: , even tried to force it in there but it was a no go..... :wall:
Soo it looks like I have to do a wee bit of modding to do on the holder so I can slip it underneath the old plate holder :rant:
Katscan
E-C LEVEL 3
Postby Katscan - June 25th, 2010, 5:45 pm
So I have to wire mine into the reverse light, anyone know which wires off hand are the ones I need to use?
Katscan
E-C LEVEL 3
Next
Return to Electrical Mods
Users browsing this forum: No registered users and 8 guests
