TSB 06-14-4
07/24/06
MERCON ATF IS BEING REPLACED BY MERCON V
ATF AS A SERVICE FLUID.
FORD:
1980-1997 Crown Victoria
1981-1997 Mustang, Thunderbird
1981-2003 Escort
1986-1993 Festiva
1986-1997 Taurus
1989-1997 Probe
1994-1997 Aspire
1995-2000 Contour
1980-1996 Bronco
1981-2003 F-150
1981-2004 E-Series, F-Super Duty
1983-1996 Ranger
1986-1996 Aerostar
1991-1997 Explorer
1993-2004 F-53 Motorhome Chassis
1995-1998 Windstar
1997-2004 Expedition
2000-2005 Excursion
2001-2007 Escape
1987-2000 F-B-Series
2000-2007 F-650, F-750
LINCOLN:
1980-1997 Town Car
1981-1997 Continental
1993-1997 Mark VIII
1998-2004 Navigator
2002-2003 Blackwood
MERCURY:
1980-1997 Grand Marquis
1981-1997 Cougar
1986-1997 Sable
1987-1999 Tracer
1995-2000 Mystique
1999-2002 Cougar
1993-2002 Villager
1997 Mountaineer
2005-2007 Mariner
MERKUR:
1985-1989 XR4TI
This article supersedes TSB 01-15-7 to update the vehicle application chart.
ISSUE
MERCON(R) Automatic Transmission Fluid is being replaced by MERCON(R) V as a service fluid.
ACTION
Beginning immediately all automatic transmission / transaxle applications requiring MERCON(R) can now be serviced using MERCON(R) V or MERCON(R) Automatic Transmission Fluid or dual usage fluids labeled MERCON(R) / MERCON(R) V. After July 1, 2007, MERCON(R) Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory.
SERVICE PROCEDURE
Service automatic transmissions requiring MERCON(R) with MERCON(R) V or MERCON(R) Automatic Transmission Fluid or dual usage fluids labeled MERCON(R) / MERCON(R) V
For proper fluid application on current and past model vehicles equipped with automatic transmissions I transaxles refer to the fluid usage chart. (Figure 1)
CAUTION
AUTOMATIC TRANSMISSIONS / TRANSAXLES THAT REQUIRE MERCON® V SHOULD STILL ONLY USE MERCON(R) V OR DUAL USAGE FLUID LABELED MERCON(R) / MERCON(R) V.
CAUTION
MERCON(R) SP, MOTORCRAFT PREMIUM AUTOMATIC TRANSMISSION FLUID AND MOTORCRAFT M5 ATFS ARE UNIQUE FLUIDS AND MUST BE USED IN APPLICATIONS RECOMMENDING THAT PARTICULAR FLUID.
USE OF ANY OTHER FLUID MAY CAUSE REDUCED FUNCTIONALITY OR TRANSMISSION DAMAGE.
CAUTION
THE FUNCTIONAL CHARACTERISTICS OF FLUIDS FOR CVT TRANSMISSIONS ARE VERY DIFFERENT THAN THOSE OF OTHER AUTOMATIC TRANSMISSION FLUIDS (ATFS).
USE OF A FLUID OTHER THAN MOTORCRAFT CONTINUOUSLY VARIABLE CHAIN TYPE TRANSMISSION FLUID OR ONE LABELED AS MEETING MERCON(R) C WILL CAUSE FUNCTIONALITY CONCERNS AND INTERNAL TRANSMISSION DAMAGE.
CAUTION
DO NOT USE AUTOMATIC TRANSMISSION FLUID SUPPLEMENTS, ADDITIVES, TREATMENTS OR CLEANING AGENTS.
Parts Block
WARRANTY STATUS: Information Only
TSB 06-14-4
07/24/06
FORD:
1981-2003 Escort
1986-1993 Festiva
1986-1997 Taurus
1989-1997 Probe
1994-1997 Aspire
1995-2000 Contour
1980-1996 Bronco
1981-2003 F-150
1983-1996 Ranger
1986-1996 Aerostar
1991-1997 Explorer
1995-1998 Windstar
2000-2005 Excursion
2001-2007 Escape
LINCOLN:
1980-1997 Town Car
1993-1997 Mark VIII
1998-2004 Navigator
2002-2003 Blackwood
MERCURY:
1981-1997 Cougar
1986-1997 Sable
1987-1999 Tracer
1995-2000 Mystique
1999-2002 Cougar
1993-2002 Villager
1997 Mountaineer
2005-2007 Mariner
MERKUR:
1985-1989 XR4TI
ISSUE
ACTION
SERVICE PROCEDURE
CAUTION
CAUTION
CAUTION
CAUTION
Parts Block
PART NUMBER | PART NAME |
XT-2-QDX | MERCON(R) (Quart) |
XT-2-DDX | MERCON(R) (55 Gal. Drum) |
XT-5-QM | MERCON(R) V (Quart) |
XT-5-DM | MERCON(R) V (55 Gal. Drum) |
