2008+ Mode Door Actuator (defrost/floor) removal/install
3.1K views 2 replies 3 participants last post by  smoke two
#1 ·
Direct image link: http://i246.photobucket.com/albums/gg10 ... oract2.jpg
Item - Part Number - Description
1 - (part of 19D887) - Defrost/panel/floor mode door actuator electrical connector
2 - (W701696) - Defrost/panel/floor mode door actuator screw (2 required)
3 - (19E616) - Defrost/panel/floor mode door actuator
Removal and Installation
NOTE: The defrost/panel/floor mode door actuator can be accessed from below the LH side of the instrument panel.
1. Disconnect the defrost/panel/floor mode door actuator electrical connector.
2. Remove the 2 defrost/panel/floor mode door actuator screws.
* To install, tighten to 3 Nm (27 lb-in).
3. Remove the defrost/panel/floor mode door actuator.
4. To install, reverse the removal procedure.
