How to change a water pump 3.0 V6
Enter your requests here. We'll try to find a guide for you!
Postby JorgeM3 - April 25th, 2011, 12:35 am
Hi I'm new.
i'm from Colombia and I have a Ford Escape 2008 3.0 V6 engine 4x4 with 60k miles.
and now I have a problem with the water pump, I need to change it. but i see the thread hear and say how, but from a water pump with tensioner, and my truck it's 3.0L (4V) it's without Tensioner... so I can't take it off two bolts because the pulley from the camshaf it's to near and now i need to take it off the pulley... but how?? I can take off the bolts from the water pump without take off the pulley? how?
Thanks a lot for your help, and Sorry about my english!!!. :wall:
JorgeM3
Re: How to change a water pump 3.0 V6
Postby SUVord - April 25th, 2011, 7:52 am
Hola and welcome!
If your engine is the same V6 as in the Escape...
...You first unbolt the water pump assembly.There are three bolts there and they are all further inward which should be no problem to reach with a spanner.
After you take the assembly off, you unscrew the water pump bolts and take it off the assembly.Make sure you use a new gasket and a new belt when you put everything back on.
Good luck.
Be cool-Be nice-LEEDS UNITED
SUVord
First poster on E-C's new server
E-C LEVEL 10
My nickname: Jacindo
My vehicle: Ford Maverick 3l XLT
My vehicle's name: Argos
Postby JorgeM3 - April 25th, 2011, 9:26 am
Hi. Thanks for your answer, I don't know wy I writhe Explorer... I'ts a ESCAPE!!! jejejeje 3.0 V6 engine.
and I can't unbolt 2 bolts because the pulley from the camshaft doesen't give a change... I gonna put some pictures ;)
JorgeM3
Postby JorgeM3 - April 25th, 2011, 11:50 am
The pics.
you can see the pulley and the pump... and the two bolts behind the pulley. how to unbolt?
thanks!
JorgeM3
Postby Squishy - April 25th, 2011, 6:31 pm
I don't have time to get the full write-up posted just yet, but the pulley has to be removed to reach those bolts.
The goggles, they do nothing!
The Garage:
Image Image Image Image
Squishy
Basket Case
E-C LEVEL 13
My nickname: Bev
Postby JorgeM3 - April 25th, 2011, 9:09 pm
Thanks Canada Panda
I can do it!!! I don't know if I do it right, but the pulley it's out!! and now I can change the pump. I try with an estractor... and the pulley it's out!
thanks!
JorgeM3
Postby SUVord - April 30th, 2011, 10:20 am
Canada Panda is right.
After looking at the pictures I realized that Ford has changed the position of the pulley and instead of taking motion from the intake valves cam as in the earlier Escapes it takes it from the Exhaust valves cam.That shifting makes it necessary for the pulley to come out in order to reach all the bolts of the water pump, unlike what was happenning with the older V6s.
Thank you both for the education.
PS.What do you cal a rim in colombian?
SUVord
E-C LEVEL 10
Return to How-To: Requests
cron
