trailering with the 4cyl
Talk about anything related to your Escape, Mariner, Tribute, Maverick!
Postby boddah77 - November 2nd, 2012, 6:11 pm
wondering how the 4 cylinder trailers...and what have you pulled?
boddah77
Re: trailering with the 4cyl
Postby Billyk - November 2nd, 2012, 6:56 pm
This is not my FEH but it sends a message:
1500lbs should not be a problem.
2005 4WD Ford Escape Hybrid
my next vehicle will be a PHEV
Billyk
E-C LEVEL 5
Congratulations on reaching 750 posts!
My vehicle: 2005 Escape Hybrid
Postby Dadof5 - November 3rd, 2012, 4:48 pm
I have a 2011 with the V6, and recently pulled a 5x8 U-Haul enclosed trailer with some furniture (not very heavy) for 750km. It pulled it, but I wouldn't call it a pleasant experience. Kept it to the speed limit (90 km/h) but it really laboured. The transmission was constantly downshifting 1 or 2 gears. Gas mileage dropped from 27 mpg (US) to just over 18 (same trip, with and without trailer).
I'm used to pulling a larger and heavier boat trailer with GM Caprice/Roadmaster V8s. Hardly know the trailer is there and only lost 3-4 mpg.
I'm sure the 4 is fine for occaisional pulling of a light trailer. if you plan to trailer regularly and longer discances, I'd think twice about the 4.
Dadof5
Postby ExplorerTom - November 3rd, 2012, 7:49 pm
Billyk wrote:This is not my FEH but it sends a message:
I've rented that trailer before- pretty sure it weighs about 1200 lbs by itself. So depending what's under the tarp, it could be much more than 2000 lbs.
ExplorerTom
E-C LEVEL 6
My vehicle: '06 Mariner & '12 Escape
Postby Knightrider03m - November 3rd, 2012, 11:27 pm
Dadof5 wrote:I have a 2011 with the V6, and recently pulled a 5x8 U-Haul enclosed trailer with some furniture (not very heavy) for 750km. It pulled it, but I wouldn't call it a pleasant experience. Kept it to the speed limit (90 km/h) but it really laboured. The transmission was constantly downshifting 1 or 2 gears. Gas mileage dropped from 27 mpg (US) to just over 18 (same trip, with and without trailer).
Turn off the overdrive. My truck likes to do that when I am not towing anything behind it. We have a every jumpy transmission.
2012 Ford Escape XLT AWD (Angel)
2004 Chevy Suburban LT 4WD (Bluebird)
Knightrider03m
E-C LEVEL 3
My vehicle: 2012 Ford Escape XLT AWD
My vehicle's name: Angel
Postby tim_d_wagner - November 4th, 2012, 1:37 am
The 1500 max rating is with no other cargo and a driver under 150lbs. To use it with anything more is unlawful and unsafe. Getting and keeping going is only part of the issue; steering and braking are also concerns.
With the good turning radius the Escapes are quite good with light trailers, but can get a little wiggly in winds. Keep in mind our Escapes are not known for having the strongest power train components.
tim_d_wagner
My vehicle: 2008 Ford Escape v6 LTD 4WD
Postby Dadof5 - November 4th, 2012, 7:49 am
I did.
Dadof5
Postby camusdarrach - November 4th, 2012, 4:52 pm
Here is my own view of the trailer towing capacity of the 4 pot Maverick..
viewtopic.php?f=3&t=17185
:angel:
The only member with both a RHD Maverick and LHD Escape
camusdarrach
E-C's only ambidextrous member and British Correspondent
E-C LEVEL 8
My vehicle: 2003 Ford Maverick 2.0 XLT,
My vehicle's name: 2002 Ford Escape 3.0 XLT Midni
Postby rlhasse - November 8th, 2012, 12:58 am
tim_d_wagner wrote:The 1500 max rating is with no other cargo and a driver under 150lbs. To use it with anything more is unlawful and unsafe. Getting and keeping going is only part of the issue; steering and braking are also concerns.
This is not accurate, it's bad information. The rated tow capacity does not have anything to do with the weight of the tow vehicle itself, it only concerns the weight of the trailer load. The gross combined vehicle weight rating concerns the combination of the trailer and the tow vehicle. To be perfectly accurate you need to weigh the trailer by itself, the tow vehicle by itself and both of them combined. But you don't have to go to that extent. Find out what the gcvwr is for your model (do a google search), that will tell you how much your tow vehicle can weigh if you already know the weight of the trailer). You can also find the curb weight of your model of tow vehicle, and if you subtract the curb weight from the maximum allowable weight it will give you the amount of cargo capacity you can haul, including passengers.
rlhasse
E-C LEVEL 1
My vehicle: 2008 XLT 4X4, 2013 SEL 4X4
Postby tim_d_wagner - November 8th, 2012, 2:13 am
rlhasse wrote:
tim_d_wagner wrote:The rated tow capacity does not have anything to do with the weight of the tow vehicle itself
Ultimately your limiting factor is GCWR(gross combined weight rating) which should be read from your vehicles sticker, not an Internet search.
A GCWR will rarely equal a vehicles GTWR(gross trailer weight rating) plus it's GVWR(gross vehicle weight rating). The expected difference between GCWR and GTWR+GVWR is why tow capacity has to do with the loading of the tow vehicle.
In order to utilize your GTWR you may need to reduce weight from your tow vehicle. In some cases we have done the math and have an idea of what the manufacturer had in mind when they came up with GCWR and give that as a valid simplified answer for a specific case.
tim_d_wagner
Next
Return to Tailgate Chat
Users browsing this forum: Yahoo [Bot] and 7 guests
