Tire Pressure and MPG
Talk about anything related to your Escape, Mariner, Tribute, Maverick!
Postby sinister mob - December 14th, 2009, 10:47 pm
So I am constantly monitoring the onboard mpg readout with every fillup. I basically drive the exact same areas which is a mix of city and highway. Not a lot of long trips yet, basically to work and back which is about 15 minutes. When I got the truck I was at 21-ish for an average and after a few tanks I was consistantly getting 23.8-24.5. The last tank I got 21. I thought maybe crappy gas at 7-11 so I avoid it now. I filled up at my Mobil the last tank and averaged 20.5. I thought to myself something isn't right. I checked the pressure on the tires and all 4 were roghly 35 psi. The Michelins say 44 psi max so I inflated to 40 on all 4. Half a tank later driving around the same roads I am back at 24 ish. It proves to me that I need to check the pressure more often. It coincides with the weather drop to freezing so I assume that with the winter temp change I just needed to fill them and keep an eye on them.
2010 XLT/Metallic Sport Blue/Stone Interior traded for the New 2012 Jeep:
Image Image
For Sale:
Sub - http://www.escape-city.com/viewtopic.php?f=21&t=6124&p=104423&sid=1d66757af904032c428422acb6ebaf97#p104423
sinister mob
E-C LEVEL 5
My vehicle: 2010 XLT, 2.5L, AWD
My vehicle's name: Club Escape
Re: Tire Pressure and MPG
Postby tajescape - December 15th, 2009, 2:56 am
Good find! I run my tires with a bit more pressure than the recommended psi from the door sticker for the same reason.
Tom
Tom
tajescape
My vehicle: 2009 Ford Escape XLT 2wd 2.5L
Postby JIMMYJOHN - December 15th, 2009, 8:57 am
I run mine at 34 psi all the time
Eat Well, Sleep Well, Exercise and Die Fit
JIMMYJOHN
The Godfather Of E-C
E-C LEVEL 18
My nickname: Snoop Dog
My vehicle: 2003xlt Scape Aspen Green 4x4
My vehicle's name: SCAPE
Postby skibender - December 19th, 2009, 9:01 am
At 40 psi, you'll probably have excessive wear in the center of the threads. 40 psi might help with mpg but it'll wear your tires out faster. The cold weather brings down mpg.
Steve
2006 Escape XLT 4WD
skibender
E-C LEVEL 1
My vehicle: 2006 Escape XLT 4x4
Postby 2010Escape - December 19th, 2009, 10:58 am
skibender wrote:At 40 psi, you'll probably have excessive wear in the center of the threads. 40 psi might help with mpg but it'll wear your tires out faster. The cold weather brings down mpg.
I agree 100%...I travel 80,000 plus KM's per year and my tires are set at 32-34psi. MPG definately decrease by 10-15% in the cold weather dependant upon driving style and length of time you let in warm up in the morning. :frozen:
2010Escape
E-C LEVEL 3
Postby sinister mob - December 19th, 2009, 7:27 pm
Hmm..... The Michelins list 44 psi max. All 4 are at 40psi and there is still a good amount of "roll" on all tires. Seems to be a nice flat contact arear on the tires. But good point that the centers might wear out faster. Maybe I'll drop back to 36 or so. I figured the colder weather would lower the mpg. especially when it is 10 F outside as of late.
Image Image
For Sale:
sinister mob
E-C LEVEL 5
Postby Squishy - December 19th, 2009, 7:38 pm
44 PSI max has no relation to your vehicle. It just means that the tire is suitable for applications that call for pressures up to 44 PSI. As long as you stay with the stock load rating, the OEM sticker lists the proper inflation. You can go 2-4 PSI higher for better gas mileage, but you may have irregular wear above that.
The goggles, they do nothing!
The Garage:
Image Image Image Image
Squishy
Basket Case
E-C LEVEL 13
My nickname: Bev
Postby jonas1022 - December 19th, 2009, 7:39 pm
I'd stay with what's printed on the door jam schedule, or in the manual. 44 psi is the max, not necessarily the recommended. :peace:
aka "David"
“Love the people who treat you right. Pray for those who don't”
jonas1022
Award-Winning Bullitt Tribute Moderator
My nickname: aka David
My vehicle: 01 Mustang Bullitt, 08 Tribute
Geez Squishy, you beat me by that much... :angel:
aka "David"
jonas1022
Postby KC5ZRQ - December 19th, 2009, 11:57 pm
You probably have touring tires on your Escape. They should hold their shape with a little extra psi with no problem. I doubt you will increase wear by increasing tire pressure, unless you pump them up way beyond their rated capacity.
2009 Ford Escape XLT: 6-Cyl/FWD | Silver/Charcoal | Sun & Sync Pkg, Side Step, Cargo Pkg
KC5ZRQ
My vehicle: '09 Escape XLT V6
Next
Return to Tailgate Chat
Users browsing this forum: Bing [Bot], Stryford and 10 guests
