Outside temp.
Re: Outside temp.
Postby mozz - April 1st, 2012, 4:36 pm
It has one.
MOTORCRAFT Part # DY1137
Ambient Air Temperature Sensor
Located in Front bumper ; Outside Temp Thermometer
2003 Ford Mustang GT 4.6l 5 speed
2007 Ford Focus SE 2.0l 5 speed
2010 Ford Escape XLS 2.5l Fwd 5 speed
2012 Ford Fusion S 2.5l 6 speed
mozz
My vehicle: 2010 XLS 2.5 Fwd Blue 5 speed
Re: Outside temp.
Postby wptski - April 1st, 2012, 5:05 pm
mozz wrote:It has one.
Earlier you stated that you don't have a dash readout, now your saying you have the sensor? Where dd you get that info and/or what makes you think that you now have a sensor?
Google comes up with: Motorcraft DY-1137 Coolant Temperature Sensor. Some sites show it as a Ambient Temperature Sensor.
Looking at the electrical diagram for my '09, the sensor mounted at near/behind the grill is the same connector shown in a diagram for the HVAC Module-EMTC. It could be that they all have the sensor which is used by the HVAC. There could be a PID for it that they found to show the readout too. Interesting.......
Bill
What a waste of space, huge pictures of your cars, lists of cars you've own, addons, etc!
wptski
E-C LEVEL 7
My vehicle: '09 Ford Escape Limited, 4WD
Re: Outside temp.
Postby mozz - April 1st, 2012, 6:53 pm
I don't have a dash readout. I have a obd ultragauge which tells me the outside temperature.
mozz
Re: Outside temp.
Postby wptski - April 1st, 2012, 7:05 pm
mozz wrote:I don't have a dash readout. I have a obd ultragauge which tells me the outside temperature.
I know that just trying to figure old how it's doing it.
Bill
wptski
E-C LEVEL 7
Re: Outside temp.
Postby mozz - April 2nd, 2012, 5:08 pm
From my knowledge(guessing), all newer models have the outside air temp sensor. It's a software thing whether or not it displays it. Many sensors are available on the obd port, so instead of paying Ford, i pay Ultragauge and get to see
Open/Closed Loop Emissions Status
Percent Engine Load
Engine coolant temperature (F)
Engine coolant temperature (C)
Short Term Fuel Trim Bank 1
Long Term Fuel Trim Bank 1
Short Term Fuel Trim Bank 2
Long Term Fuel Trim Bank 2
Intake Manifold Absolute Pressure (MAP) PSI
Intake Manifold Absolute Pressure (MAP)(kPa)
RPM
MPH
KPH
Ignition Timing Advance
Intake Air Temperature (F)
Intake Air Temperature (C)
Mass Air Flow Sensor output in grams/sec
Absolute Throttle Position Percentage
Bank 1 Oxygen Sensor 1 Voltage
Bank 1 Oxygen Sensor 2 Voltage
Bank 2 Oxygen Sensor 1 Voltage
Bank 2 Oxygen Sensor 2 Voltage
ECM RUN TIME
Distance traveled with Check Engine Light on (miles)
Distance traveled with Check Engine Light on (km)
Commanded EGR Flow Percent
Commanded EGR Flow Error Percent
Commanded Evaporative purge Percent
Fuel Level Percent
Number of warm-ups Since Check Engine Light cleared
Distance traveled since Check Engine Light cleared (miles)
Distance traveled since Check Engine Light cleared (km)
Evaporative System Vapor Pressure (PSI)
Evaporative System Vapor Pressure (Pa)
Barometric Pressure (inHg)
Barometric Pressure (kPa)
Catalytic Converter Bank 1 Sensor 1 Temperature (F)
Catalytic Converter Bank 1 Sensor 1 Temperature (C)
Catalytic Converter Bank 2 Sensor 1 Temperature (F)
Catalytic Converter Bank 2 Sensor 1 Temperature (C)
Battery Voltage
Relative Throttle Position Percentage
Ambient Air Temperature (F)
Ambient Air Temperature (C)
Boost Pressure, (Relative Pressure) (PSI)
Boost Pressure, (Relative Pressure) (kPa)
Brake Horsepower 1
Brake Kilowatts 1
Torque 1 (ft lbs)
Torque 1 (N.m)
Brake Horsepower 2
Brake Kilowatts 2
Torque 2 (ft lbs)
Torque 2 (N.m)
Volumetric Efficiency
Mass Air Flow 2, Calibrated/Calculated
Instantaneous MPG
Intantaneous Gallons/Hour (GPH)
Instantaneous KPL
Intantaneous Liters/Hour
Instantaneous L/100km
Distance to Empty(DTE)(miles)
Distance to Empty(DTE)(km)
Time to Empty (TTE)
Fuel Level (gallons)
Fuel Level (liters)
Oil Distance(miles)
Oil Distance(km)
Service Distance(miles)
Service Distance(km)
General Purpose
Average MPH
Average MPG
Average Gallon/Hour (GPH)
Fuel Used (gallons)
Run Time
Distance (miles)
Average KPL
Average L/100km
Average KPH
Average Liters/Hour
Fuel Used (liters)
Distance (km)
TRIP GAUGES
Run Time
Average MPH
Average MPG
Fuel Used Gallons
Average Gallon Per Hour (GPH)
UltraGauge Internal Temperature (F)
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
UltraGauge Internal Temperature (C)
SHORT TRIP GAUGES
Run Time
Avergage MPG
Fuel Used (gallons)
Average gallons/hour
Average MPH
Distance (miles)
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
mozz
Re: Outside temp.
Postby wptski - April 2nd, 2012, 7:15 pm
Can it log 20 PIDs at different time intervals at one time, load into a PC, graph the output and export into MS XL? That what my old/obsolete scanner can do. A newer one will probably do more and better!
Bill
wptski
E-C LEVEL 7
Re: Outside temp.
Postby hworksinc - April 2nd, 2012, 10:04 pm
wptski wrote:The ambient temperature is a seperate sensor located just behind the front grill or so the manual states. It has nothing to do with the climate control, why should it? There's is another temperature sensor as part of the AC unit to make condensation doesn't freeze. There's another temperature sensor for the interior too.
Although the Canadian Escape for '09 had DRL enabled, the service manual didn't show it as a feature that could be enabled. I've never heard of any '09 owner having it enabled, not that there wasn't just never posted.
Why would one need DRL while in Park?
Yes, the sensor is located behind the grill. However, the ambient air sensor DOES indeed interface to the climate control module. The temperature information is passed on to the display via the medium speed module communications network. Any other device on the MS-CAN network (like a reader) could also access the temperature information. See here:
Manual controls:
Automatic controls:
This is why it's complicated to get the temperature sensor working on a vehicle that was not configured for it originally - at least 2 devices (the EMTC/DATC module and the FDIM) must be properly programmed, and the sensor must be present and working.
As an aside, the DRL thing was just an observation - there's absolutely no reason for them to be on in park. That's just how GM vehicles used to work.
hworksinc
My vehicle: 2012 Escape XLT 4x4
Re: Outside temp.
Postby wptski - April 3rd, 2012, 7:43 am
hworksinc wrote:Yes, the sensor is located behind the grill. However, the ambient air sensor DOES indeed interface to the climate control module. The temperature information is passed on to the display via the medium speed module communications network. Any other device on the MS-CAN network (like a reader) could also access the temperature information.
I guess that you didn't read my post above where I looked at my manual and seen the same diagrams that you posted? Yes, I now agree with you.
I wonder if GM uses a reduced output while in DRL like Ford does?
BTW: Where are you getting the diagrams from?
Bill
wptski
E-C LEVEL 7
Re: Outside temp.
Postby jpark - April 3rd, 2012, 7:59 am
I was going to post the same diagrams.
I spoke with a Ford electrical engineer when the other thread was being discussed, and he said that the EMTC and DATC modules are programmed at the factory. They can't be flashed in the field, and the programming is not related to the Smart Junction Box. He said that your best bet is to find a module from wrecked Escape with factory outside temperature.
The FDIM does not need to be programmed, since the signals controlling it are sent on the MSCAN "network".
2016 Ford Escape Titanium 4WD, Magnetic Metallic, Charcoal Heated Leather, new 9/23/2015
- 2.0L EcoBoost I4, 6-speed auto, 301A, Sync 3/Sirius/HD, Panoramic Roof, Navigation
- Husky WeatherBeater 99741/23741 mats, Ford factory splash guards
2008 Ford Fusion SE FWD, Black, Charcoal/Red leather, new 2/23/2008, still strong and trouble-free
- 2.3L I4, 5-speed auto, Sync, Sport Appearance/Moon 'N Tune/Ambient Lighting packages, Husky WB 98301 mats
2013 Ford Escape Titanium 4WD, Ruby Red Metallic, Charcoal Leather, new 11/2/2012, sold 9/23/2015
2010 Ford Escape Limited FWD, Black, Camel Leather, new 4/22/2010, sold 11/2/2012
2007 Ford Edge SEL Plus AWD, Blazing Copper Metallic, Charcoal Leather, new 6/18/2007, sold 4/22/2010
2005 Ford Escape Limited 4WD, Redfire Metallic, Pebble Leather, new 6/4/2004, sold 6/18/2007
jpark
E-C Administrator
My nickname: JP
My vehicle: 2016 Escape Titanium 2.0EB 4WD
Re: Outside temp.
Postby wptski - April 3rd, 2012, 8:10 am
jpark wrote:I was going to post the same diagrams.
That does explain how the UltraGuage reads the ambient temperature without having the right EMTC, etc. modules.
Bill
wptski
E-C LEVEL 7
PreviousNext
Users browsing this forum: Google [Bot] and 35 guests
