2010 Escape 4-cyl CEL P144a Purge Valve
Postby Cajun Okie - December 3rd, 2012, 11:28 pm
New to the forum. Tried to search this, but didn't find a whole lot. Thanks in advance for any help you all may provide!
I have a 2010 Escape with the 2.5L I-4 with 52000 miles, and it recently had a CEL and was having some issues with hard starting, especially after refueling. Took it to my local Autozone, and got the code P144a, which relates to the evap canister and its purge valve. I see this is a relatively common problem on all Escapes based on some googling and searching on the forums. Instead of taking it to the dealer and letting them charge me $100 just for diagnosis, I'd like to change the purge valve and see if this takes care of it. Part is only $40...
Problem is, I am having trouble finding the purge valve to replace it... I found another thread here with a pic of the engine bay on a 2.3L I-4 with the valve located near the intake, but it's not in the same spot on the newer models.
Anyone ever done this before or know where to find the evap canister purge valve? Thanks!
Cajun Okie
Re: 2010 Escape 4-cyl CEL P144a Purge Valve
Postby Cajun Okie - December 19th, 2012, 3:13 pm
Still having this issue... No luck on any knowledge on this subject?
Cajun Okie
Postby tang - December 19th, 2012, 3:16 pm
I'm kinda curious if this is covered by the 60K powertrain warranty. I'll check the parts list at home to see if it shows where the part might sit.
PM with wheel questions.
past: 09 Escape XLT V6 AWD
present: 15 Taurus SEL AWD
tang
E-C LEVEL 16
My vehicle: 09 ESC XLT 4WD V6
Postby underthetire - December 19th, 2012, 3:59 pm
Might see if it's under the emissions warranty.
http://www.epa.gov/oms/consumer/warr95fs.txt
underthetire
E-C LEVEL 8
My vehicle: 2009 xlt sun and sync 2.5
My vehicle's name: Money saver
Postby bluto - December 19th, 2012, 9:57 pm
The purge valve is under the hood near the master cylinder. You should see a hose going over to the intake and another disappearing down under the car. There is also a test port with a green cap on it.
Current: 2008 Escape XLT
Previous: 2002 Tribute ES V6
bluto
Congratulations on reaching 250 posts!
My vehicle: 2008 Escape XLT
Postby Cajun Okie - January 13th, 2013, 10:53 am
So, sorry for late reply, but I have an update.
Our Escape was doing great for a while. CEL turned off and previous symptoms disappeared. I decided I'd just see what happens. Well, a little later, CEL came back on, and after a fill-up with gas, it had some trouble starting. I decided I would search for this thing one more time. Turns out (as Bluto pointed out above) it IS under the hood, between the throttle body and the radiator. I changed it out yesterday. We'll see if the CEL goes off after a few days. Thanks for all the help on this forum!
Cajun Okie
Postby Cajun Okie - January 20th, 2013, 10:42 am
I will continue to update this thread so that someone in the future with the same problem may find it and use it to their advantage.
So, the CEL continued to glow amber until today, over a week after install of the new purge valve. This morning, the wife went out to the car, CEL is off, and it has been symptom free since the replacement. If we are trouble free from here on out, I will have saved around $200. The stealership wanted $100 just to diagnose it!
Thanks for the help of the forum.
Cajun Okie
Postby tang - January 20th, 2013, 1:40 pm
For the record, most dealerships if not all waive the diagnosis if the repair is done there. Pros and cons.
Glad to hear you got it resolved.
tang
E-C LEVEL 16
Postby RichLee0717 - January 24th, 2013, 12:27 pm
I have a 2010 Mazda Tribute and yesterday my check engine light came on and I took it to AutoZone and got the code P144A. They didn't know what it meant so I took it to my dealer this morning. They told me I need to replace the evaporative canister and purge valve and quoted me $515 to fix it. Sounds pretty similar to this story. Is that a fair price? Any thoughts? I have no idea what I am doing under the hood other than the basics so I don't really want to mess with it myself.
RichLee0717
Postby bluto - January 24th, 2013, 8:03 pm
The dealer is full of it. Emissions equipment is covered by warranty for five years or 50,000 miles per the feds. Go back and tell them to fix it.
http://www.motortrend.com/cars/2010/mazda/tribute/i_sport_sport_utility/2141/warranty/
bluto
Next
Users browsing this forum: mattc, The Pope and 28 guests
