Escape 2002 coils
Escape 2002 coils
Postby Ecovan150 - May 14th, 2013, 8:14 pm
don't understand this coils !!!
ford escape have 6 coils cop and when i use my multimeter to measure current resistance or ohms on all coils it sad, 0.8 ... in all coils, but num # 5 its bad nooo curret spark on it . ...i just want to now what is my confused of this measure and why she don't work and the others works..? :confused:
don't now :?
.............................................FORD...........................................
Ecovan150
My nickname: CHICO
My vehicle: 2002 Ford Escape XLT 3.0 V6
Re: Escape 2002 coils
Postby mozz - May 14th, 2013, 8:51 pm
Coils are like transformers, you are measuring one side, most likely the primary. Also, your meter may not be able to measure any shorted turns.
2003 Ford Mustang GT 4.6l 5 speed
2007 Ford Focus SE 2.0l 5 speed
2010 Ford Escape XLS 2.5l Fwd 5 speed
2012 Ford Fusion S 2.5l 6 speed
mozz
My vehicle: 2010 XLS 2.5 Fwd Blue 5 speed
Postby Ecovan150 - May 14th, 2013, 10:05 pm
well thanks :thumb: that's the problem then.
Ecovan150
My nickname: CHICO
Postby bluto - May 14th, 2013, 11:03 pm
Also the epoxy potting is prone to very small cracks with age and heat exposure. Said cracks allow moisture in and can cause misfires. A coil in this condition may work fine in Arizona, but take a drive to Florida and you might start having misfires.
bluto
Congratulations on reaching 250 posts!
My vehicle: Mazda Tribute 2002 ES-V6 4WD
Postby Ecovan150 - May 15th, 2013, 2:05 am
oooo its about temp, good news to me
Ecovan150
My nickname: CHICO
Postby 2013scape - May 16th, 2013, 1:33 pm
You should also make sure you change your plugs when that time comes around. If the plug is not working at peek performance (wearing out) the juice going through the coil can cause it to get hotter than normal (won't melt it) and can cause the epoxy problems.
2013scape
Postby Ecovan150 - May 16th, 2013, 1:50 pm
:thumb: ok thanks i check the plugs good
Ecovan150
My nickname: CHICO
Postby Gil_Jrz - May 20th, 2013, 11:54 am
I have experienced some misfires on my '04 XLS V-6 during some of the damp weather we have been having here in the northeast. Pretty sure it's an ignition issue. Misfired on the no. 5 cylinder, according to my scanner. Was going to replace the boots, but then I saw a set of six coils available from several different vendors on ebay for under $60! The brand is "Herko". I have never heard of this manufacturer before. A set of six coils for under $60 seems really inexpensive. When I have replaced COP-type coils on other vehicles, they have typically been $80 to $150 each. Has anybody used these Herko coils? I am curious if they are a decent product, or junk?
Gil_Jrz
Postby Ecovan150 - May 20th, 2013, 12:56 pm
iam goint to check this week when i receive it from ebay the yellow one 6 packs.
Ecovan150
My nickname: CHICO
Postby jbone2470 - May 21st, 2013, 6:07 pm
Gil_Jrz wrote:I have experienced some misfires on my '04 XLS V-6 during some of the damp weather we have been having here in the northeast. Pretty sure it's an ignition issue. Misfired on the no. 5 cylinder, according to my scanner. Was going to replace the boots, but then I saw a set of six coils available from several different vendors on ebay for under $60! The brand is "Herko". I have never heard of this manufacturer before. A set of six coils for under $60 seems really inexpensive. When I have replaced COP-type coils on other vehicles, they have typically been $80 to $150 each. Has anybody used these Herko coils? I am curious if they are a decent product, or junk?
It is a hit or miss on quality on ebay coils at that price.Some have had no issues, others had to replace them.To me if i gonna replace the coils i gonna get the dealer ones and be done with it.
Since they about $125 each from dealer,i only bought the back 3 coils at once and then replaced the front 3 at another time.Since the back 3 are hard to do without takin intake off.
So if ya gonna do plugs and have money issues only replace the rear 3 coils and put one of the good ones from rear to front cyl u havin problems with so then when ya do have money u can easliy replace the front coils with ease..
Also keep in mind to check the intake gaskets as they are known for leaks and misfires.And they cheap to buy so it great time to check and replace them when u have the intake off.
Also might as replace pcv valve too when intakie off.Much easier to get at..
Also the symptoms u having are a known issue with coils going bad with damp weather..Get the whole coil replaced if ya have over 100,000 miles and dont drive around with a misfire,it will cause more costly problems for ya..
Go motorcraft for coils IMO.
"Everyone Deserves A Second Chance"
Hella 500 FogLights,Aries Brushguard,Firestone Destination A/T's,Pioneer avh-p3300BT,UltraGuage EM,GArmin GPS,OEM Molded MudFlaps,AVS VentVisors,And many More to come....
jbone2470
E-C LEVEL 14
My nickname: JBONE
My vehicle: 2004 Ford Escape Limited4x4 V6
My vehicle's name: JBONE
Next
Users browsing this forum: Andfroe, Google [Bot], JohnCT, wptski and 51 guests
