02 front end noise
02 front end noise
Postby simp6216 - December 19th, 2011, 4:52 am
Hello to all,
New member here with a problem on my girlfriends 2002 ford escape FWD 92000 miles that she bought new.
Front end (creaking) noise only while turning right that is getting louder as time goes by.
Noise is made only when turning right with engine running or not, with car moving or not.
I can't seem to locate this noise. It seems to be coming from front right.
What I have done so far:
Balljoints and outer tie rod ends have no movement
Sway bar links have no movement
Sprayed (lubed) various chassis parts (noise continued)
Lubed gasket where steering column goes thru fire wall
Checked for loose chassis parts
Noise is quieter while on jack stands (no weight on front end)
I even slit the boots on the tie rods to get some lube inside
My thought is to start throwing parts at this problem since everything is original.
Monroe quick struts
2 New outer tie rod ends
Sway bar links
Then alignment
Help any other ideas :? thanks
simp6216
Re: 02 front end noise
Postby nfdude04 - December 19th, 2011, 2:49 pm
Hi! and Welcome!!
I have a high mile 01 Escape. When I bought it, it had had some noises in the front end. I had a rattle noise in the front end which happened to be worn sway links. And I had a slight creaking sound that went away after replacing the struts (may have been the strut bearings). My guess would be your creaking sound is caused by the struts as well. Just be sure its a creaking sound and not a light crunching sound...because when my wheel bearing went bad it made some sounds when turning! hope this helps!
PS You probably think I drive a lemon but I don't ;) My Escape had 200,000+ miles on it and it was ready for some front end work since everything was original...and now drives like new again! :yahoo:
2002 Ford Escape XLS 2.0 4x4- Daily Driver
2001 Ford Escape XLT 3.0 4x4 -Retired with 285,000+ miles!
2002 Ford F-350 4x4 7.3 Diesel- My big toy
1996 Ford Mustang GT - My fast toy (had it over 10 years!)
nfdude04
My nickname: nfdude04
My vehicle: 02 Escape XLS 2.0 5-speed 4x4
Postby jpark - December 19th, 2011, 2:55 pm
That's even more amazing when you consider that yours is a first-year model!
:thumb:
2016 Ford Escape Titanium 4WD, Magnetic Metallic, Charcoal Heated Leather, new 9/23/2015
- 2.0L EcoBoost I4, 6-speed auto, 301A, Sync 3/Sirius/HD, Panoramic Roof, Navigation
- Husky WeatherBeater 99741/23741 mats, Ford factory splash guards
2008 Ford Fusion SE FWD, Black, Charcoal/Red leather, new 2/23/2008, still strong and trouble-free
- 2.3L I4, 5-speed auto, Sync, Sport Appearance/Moon 'N Tune/Ambient Lighting packages, Husky WB 98301 mats
2013 Ford Escape Titanium 4WD, Ruby Red Metallic, Charcoal Leather, new 11/2/2012, sold 9/23/2015
2010 Ford Escape Limited FWD, Black, Camel Leather, new 4/22/2010, sold 11/2/2012
2007 Ford Edge SEL Plus AWD, Blazing Copper Metallic, Charcoal Leather, new 6/18/2007, sold 4/22/2010
2005 Ford Escape Limited 4WD, Redfire Metallic, Pebble Leather, new 6/4/2004, sold 6/18/2007
jpark
E-C Administrator
My nickname: JP
My vehicle: 2016 Escape Titanium 2.0EB 4WD
Postby jbone2470 - December 19th, 2011, 4:30 pm
My thoughts are also the struts,have u tried pushing it up and down on front of escape to see how struts are reacting,leaking?..if not that and since u have down almost everyhting else maybe it could be lower control arm bushings.. :? creaking noises usually equate to suspension problems, So check all bushings and joints.. :peace:
"Everyone Deserves A Second Chance"
Hella 500 FogLights,Aries Brushguard,Firestone Destination A/T's,Pioneer avh-p3300BT,UltraGuage EM,GArmin GPS,OEM Molded MudFlaps,AVS VentVisors,And many More to come....
jbone2470
E-C LEVEL 14
My nickname: JBONE
My vehicle: 2004 Ford Escape Limited4x4 V6
My vehicle's name: JBONE
Postby simp6216 - December 19th, 2011, 5:05 pm
I ruled out wheel bearings simply because the noise happens even if the car isn't moving. The struts seem to react fine with the bounce test. Since this noise has been going on for several weeks, I dropped it off at the local Sears auto center which is 2 blocks from home. They said that they would do a free check and give me an estimate. Right outer tie rod end is bad along with alignment and labor $222. I'll fix myself tomorrorw or Wednesday and let you know. Thanks for all your replies.
simp6216
Postby simp6216 - December 20th, 2011, 6:13 pm
changed the drivers outer tie rod end and the creaking noise went away. Changed the drivers side also. Thanks for the help
simp6216
Users browsing this forum: Google Adsense [Bot], iLoveMyExploder, jfs 1232, MSNbot Media, Squirrel and 51 guests
