2004 Escape V6 Oxygen Sensor Replacement
Postby tuloon - February 13th, 2012, 4:41 pm
Hi, I am sure this question has been asked before, but I tried to some searching on the topic with not much luck on the 2004 Escape.
Anyway I was wondering if there are any diagrams that show the location of each oxygen sensor. I read something on this forum that said they were somewhat difficult to find and wanted to do some research before I get into it.
Im extremely new to this, but any help would be appreciated.
tuloon
Re: 2004 Escape V6 Oxygen Sensor Replacement
Postby simplyphp - February 13th, 2012, 4:53 pm
Before you spend $50+ ea., what is making you believe you need to replace an O2 sensor?
Are you throwing a code/codes? What are the codes?
"Not building a car from the ground up to handle the power you want to make is like Reverse Jenga; the more you pile on, the higher chance its going to topple over." - Me
"AFR 225's and LS2 strokers go together like baseball and hot dogs (with a beer of course)." - Tony Mamo
simplyphp
E-C LEVEL 1
My nickname: BornSUPERCHARGED
My vehicle: 2004 Ford Escape XLT
My vehicle's name: Supercharged 402 Corvette
Postby RobtRoma - February 13th, 2012, 4:55 pm
The real art of conversation is not only to say the right thing at the right time,
but also to leave unsaid the wrong thing at the tempting moment...
RobtRoma
Super Moderator and E-C's 100,000th AND 200,000th Poster
My nickname: Rob
My vehicle: 2002 XLT 4x4
My vehicle's name: The Mean Green Machine
Postby jbone2470 - February 13th, 2012, 5:02 pm
Ya sometimes the o2 sensors might be reacting to another problem like a lean/rich condition caused by something else.
"Everyone Deserves A Second Chance"
Hella 500 FogLights,Aries Brushguard,Firestone Destination A/T's,Pioneer avh-p3300BT,UltraGuage EM,GArmin GPS,OEM Molded MudFlaps,AVS VentVisors,And many More to come....
jbone2470
E-C LEVEL 14
My nickname: JBONE
My vehicle: 2004 Ford Escape Limited4x4 V6
My vehicle's name: JBONE
Postby tuloon - February 13th, 2012, 5:31 pm
Check engine light was on so I took it to a shop and they did a diagnostic on it and told me the oxygen sensor needed replaced. Thought the price was way too high so I want tp see the difficulty of replacing it myself.
tuloon
Postby Brenone - February 13th, 2012, 10:07 pm
If that's the problem, replacing the O2 sensor is a fairly easy fix. I have 3 of them on my Lexus & they are expensive if they go. :shock:
Don't drive faster than your Guardian Angel can fly!...Bren
Brenone
My nickname: Bren
My vehicle: 2009 Ford Escape XLT V6 4WD
My vehicle's name: Escape One
Postby tuloon - February 13th, 2012, 10:11 pm
Hey again.
I got the error code back from the shop. It is PO430 CAT Efficiency below spec. I am guessing this is the rear O2 sensor. I am wondering which of the two links in the above post do I follow and what is the difficulty of replacing this sensor.
tuloon
Postby simplyphp - February 14th, 2012, 10:37 am
tuloon wrote:Hey again.
Yeah, that's why I asked - it's not your O2 sensor that's bad.
There's two threads that might interest you.
First: viewtopic.php?f=8&t=12242
Second: viewtopic.php?f=8&t=10057&start=110 , and a quote from it (my experience this past week which I dealt with the CEL w/P0430 being on for half a year):
simplyphp wrote:By the way, in case anyone is wondering.. I have a 2004 Ford Escape XLT V6 3.0L - it was my understanding that the 3L V6 2001-2004 exhaust manifolds were interchangeable but 2005-2007 would not work. I did a little researching and compared some part numbers, and I figured out that you can get the exhaust manifold from any 2001-2007, they're all the same 3L V6.
So I bought a left (bank 2, front of car) exhaust manifold that came off a totaled 2007 Ford Escape V6 with low miles - paid $145 shipped. Got the gaskets from RockAuto, did some shopping around (spent like 2 hours driving around going into every shop I saw) for the swap and I had some really widely varying quotes to get it done.. from a few hundred to over a grand. Finally found a shop that did it for $120 and completed the swap in about 3 hours.
We've already driven the car about 125miles now, the check engine light has not come back on/there are no codes being thrown. The car does feel like it drives a bit smoother, especially higher up in the RPM band. Kind of like the car was choking up top a bit previously and is now breathing better.
So if you're getting P0430, you'll need to replace the exhaust manifold that's by the radiator. I got lucky and paid $280 total for parts, gaskets and labor. Just in time to pass my march inspection :happy:
simplyphp
E-C LEVEL 1
Postby tomw - February 15th, 2012, 1:01 pm
Stolen from: http://www.obd-codes.com/p0430
A code P0430 may mean that one or more of the following has happened:
* The catalytic converter is no longer functioning properly
* An oxygen sensor is not reading (functioning) properly
* There is an exhaust leak
Possible Solutions
First, inspect for exhaust leaks.
Next step is to measure the voltage at the oxygen sensor on Bank 2. In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
snip.... snip snip
The O2 sensor may be failing to detect the actual exhaust gas reading, so before condemning the catalytic converter, I would check the O2 sensor for proper operation. A lot cheaper, and easier to do than replacing the manifold.
tomw
E-C LEVEL 7
Location: NW Atlanta GA burbe - toenails of the foothills
My nickname: tom
My vehicle: 07 mariner 2wd v6
My vehicle's name: moby the white whale
Postby simplyphp - February 15th, 2012, 2:42 pm
tomw wrote:The O2 sensor may be failing to detect the actual exhaust gas reading, so before condemning the catalytic converter, I would check the O2 sensor for proper operation. A lot cheaper, and easier to do than replacing the manifold.
Well more than likely it's going to be a waste of money replacing it, see below:
slavrenz wrote:With all due respect, I'm not at all surprised that [replacing the rear O2 sensor] didn't work. For some reason, many people think that a bad rear O2 sensor can cause a low efficiency reading for the catalytic converter. A little understanding of OBDII theory goes a long way here. The O2 sensors monitor the oxygen content in the exhaust as compared to the outside air - in the exhaust before the catalytic converter, the oxygen content is rapidly changing because of unburned hydrocarbons, NOx, carbon monoxide, and other pollutants that are present in varying quantities; thus, the front O2 sensor fluctuates quite rapidly. Ideally, this exhaust then gets treated by the catalytic converter, which removes most of these pollutants and makes the oxygen level much more stable; as a result, the rear O2 sensor fluctuates very slowly when the converter is working properly. An efficiency threshold code gets set because the car sees both the front and rear O2 sensors as fluctuating at close to the same speed, implying that the catalytic converter is no longer doing a whole lot to stabilize the oxygen content in the exhaust and remove pollutants.
If you understand this, then it becomes clear that the rear O2 sensor should be one of the last things to check. If the rear sensor goes bad, it is going to typically make the sensor less responsive, which means that the voltage will fluctuate more slowly or erratically. If the sensor's fluctuation slows down, the car would actually interpret this as an increase in the converter's efficiency, since it interprets a slower fluctuation as a more stable oxygen content. If, on the other hand, the front O2 sensor were to go bad, it would slow down that sensor's fluctuation or make it more erratic as well. If this fluctuation rate gets sufficiently close to that of the rear O2 sensor, the converter efficiency code would trip, even if the converter was in fact properly functioining.
The only way that a converter efficiency code could be caused by a bad rear O2 sensor is if the sensor's voltage fluctuation somehow sped up relative to the front sensor. Since this is highly unlikely to occur due to a sensor malfunction, the rear O2 sensor will almost never be the cause of a converter efficiency code. This, of course, assumes that there are no codes set for the O2 sensors themselves - those should always be diagnosed first.
The point is that if you have a converter efficiency code pop up, I would start by replacing the front O2 sensor (there's a good chance that this will help bring back some of your vehicle's mpg's and performance anyways). If that fails, then there are only a limited number of other reasons for the code, and a bad rear O2 sensor is almost certainly not one of them (in the repair manual for my other car, testing the rear O2 sensor is not even listed as a step in the troubleshooting process when a converter efficiency code pops up). At that point, I would make sure that I didn't have any exhaust leaks in front of the converter (this could also throw off the oxygen readings and make the car think that the cat isn't working right), and if the car has sufficiently high mileage, I would go ahead and replace the cat (assuming you've corrected for any obvious reasons for failure, such as a misfire). If the car is less than 8 years old and has less than 80k miles, the dealer is obligated to fix your converter for free per a federal mandate through the EPA, so take your car to them and be done with it.
I hope this helps...
From here, the first link I mentioned: viewtopic.php?f=8&t=12242
simplyphp
E-C LEVEL 1
Next
Users browsing this forum: Bing [Bot], JohnCT, wptski, Yahoo [Bot] and 48 guests
