According to the user manual (page 60)l, you should be able to use the keyless entry keypad on the side door AND set memory seats 1 or 2. Has anyone been able to do this? Mine does not work. Cheers, Rollsplat
Manual Says:
Programming a Personal Entry Code To create your own personal entry code:
1. Enter the factory set code.
2. Press the 1·2 on the keypad within fiveseconds.
3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
4. For memory recall feature, enter the sixth digit 1·2 to store driver 1 settings or 3·4 to store driver 2 settings. Note: Pressing 5·6, 7·8, or 9·0 keypad numbers as a sixth digit will not recall a driver memory setting. Note: The factory-set code cannot be
associated with a memory setting.
5. The doors will lock then unlock to confirm that your personal entry code has been programmed.
You may also program a personal entry code through the MyFord Touch® system (if equipped). See General Information (page 326).
Tips:
• Do not set a code that uses five of the same number.
• Do not use five numbers in sequential order.
• The factory set code will work even if you have set your own personal code
