Whine / Whirring noise at highway speed
Postby travelover - August 19th, 2012, 8:54 pm
OK, this one has me stumped so far. My 2007 Escape Hybrid, 59,000 miles, makes a whirring or whine sound at highway speeds when going straight. (it sounds similar to axle gear noise - about 300 to 400 HZ) If I turn the steering wheel to the left, it gets much louder. If I turn to the right, it nearly stops. I jacked up all 4 corners and grabbed the tires and did a wheel rocking test. The right front wheel had play so I had the wheel bearing and outer tie rod replaced. To my shock, the noise is totally unchanged! Now it is getting louder on a coast as well as turning left.
Tires have about 5000 miles - Conti CrossContacts.
Any suggestions? :confused:
travelover
Re: Whine / Whirring noise at highway speed
Postby tuxtanium - August 19th, 2012, 9:01 pm
Could also be a CV joint.
tuxtanium
tuxtanium
E-C LEVEL 5
My nickname: G
My vehicle: 2014 Ford Focus Titanium HB
My vehicle's name: Black Betty
Postby travelover - August 19th, 2012, 9:41 pm
lilblue wrote:Could also be a CV joint.
Don't CV joints make a clicking or knocking noise? This is a high pitched whine.
travelover
Postby tuxtanium - August 19th, 2012, 10:11 pm
When they get really bad, yeah. Did this start before putting on the Contis?
tuxtanium
tuxtanium
E-C LEVEL 5
My nickname: G
Postby travelover - August 19th, 2012, 10:39 pm
lilblue wrote:
travelover wrote:
No, it started about 300 - 500 miles ago, after Contis were installed.
travelover
Postby jbone2470 - August 20th, 2012, 12:55 pm
Any leaks near where axle goes into trans? Maybe a bad axle bearing.Usually what u describe is a wheel bearing.gets louder when turning wheel to left,usually means right wheel bearing.
Could it be steering related? How the fluid..I not that familiar with hybrids.Could be any number of things on that right side..
Its not the tire? i would check that wheel bearing again closely..
"Everyone Deserves A Second Chance"
Hella 500 FogLights,Aries Brushguard,Firestone Destination A/T's,Pioneer avh-p3300BT,UltraGuage EM,GArmin GPS,OEM Molded MudFlaps,AVS VentVisors,And many More to come....
jbone2470
E-C LEVEL 14
My nickname: JBONE
My vehicle: 2004 Ford Escape Limited4x4 V6
My vehicle's name: JBONE
Postby travelover - August 20th, 2012, 4:42 pm
jbone2470 wrote:Any leaks near where axle goes into trans? Maybe a bad axle bearing.Usually what u describe is a wheel bearing.gets louder when turning wheel to left,usually means right wheel bearing.
Could it be the rear wheel bearing? It doesn't feel loose.
Not power steering - it is electric.
travelover
Postby tang - August 20th, 2012, 6:36 pm
I would've guessed a bearing.
PM with wheel questions.
past: 09 Escape XLT V6 AWD
present: 15 Taurus SEL AWD
tang
E-C LEVEL 16
My vehicle: 09 ESC XLT 4WD V6
Postby travelover - August 20th, 2012, 6:41 pm
Tang wrote:I would've guessed a bearing.
Me, too. :confused:
I was certain that replacing the RF bearing would nail it. Is is possible that the rear wheel bearing on the right side is bad, even though it feels tight?
travelover
Postby jbone2470 - August 20th, 2012, 7:01 pm
You could jack up and put gear in neutral and spin wheels manually and listen for any scraping or anything abnormal..Be careful watch for car to roll, chock wheels that are on ground.
jbone2470
E-C LEVEL 14
My nickname: JBONE
Next
Users browsing this forum: No registered users and 39 guests
