Liftgate Rattle '09 Escape
Postby DaveJ - December 10th, 2012, 4:40 pm
After about 50K miles my Escape now has a liftgate rattle coming from the post & lock assembly. I wrapped the post with electrical tape and the rattle went away. However, this lasted only about 2 weeks and I had to replace the tape.
Does anyone know of a somewhat permanent fix for this problem? Does the liftgate need adjustment? Will the lock post just unscrew so I can attempt to install some sort of rubber or plastic sleeve over the post?
Thanks.
2009 Escape Limited FWD V6 Sync Audiophile
DaveJ
E-C LEVEL 3
My vehicle: 2009 Escape Limited V6 FWD
Re: Liftgate Rattle '09 Escape
Postby Domain - December 10th, 2012, 5:29 pm
Not related, but lubricate your liftgate glass as well. That one was giving me grief recently, and was silenced by the addition of black lithium grease. May also prove availing for the liftgate latch assembly as well.
Domain
Current: 2014 Ford Taurus SEL AWD
Prior Fleet:
2005 Ford Five Hundred SEL AWD (now in Ohio)
2008 Ford Fusion SE AWD (total loss at hands of second owner)
2011 Ford Escape XLT AWD (sold, hopefully to a good home locally)
2013 Ford Taurus SEL FWD (sold, hopefully to a good home locally)
Fleet not owned, but cared for:
2010 Ford Escape XLT AWD (3.0L)
30 NY Counties - 3 States/Provinces - 2 Countries - 1 Escape
Need to pull more than just OBD Data? See this thread.
Thinking of putting HID's in your reflector headlamps? STOP! Read this first.
Is your vehicle under a Ford/Lincoln/Mercury recall? Check here.
Domain
First poster on E-C's THIRD new server
E-C LEVEL 7
Location: The Land of Snow, more commonly known as Buffalo, New York
My vehicle: 2017 Explorer Limited 4x4 2.3L
My vehicle's name: Natasha
Postby tang - December 10th, 2012, 7:06 pm
Apparently the glass hinges on my Escape were worked on at one time when I ran this complaint by the dealership, but they also had to readjust the locking mechanism on the liftgate itself on my Escape.
PM with wheel questions.
past: 09 Escape XLT V6 AWD
present: 15 Taurus SEL AWD
tang
E-C LEVEL 16
My vehicle: 09 ESC XLT 4WD V6
Postby FordService - December 12th, 2012, 4:19 pm
DaveJ wrote:After about 50K miles my Escape now has a liftgate rattle coming from the post & lock assembly. I wrapped the post with electrical tape and the rattle went away. However, this lasted only about 2 weeks and I had to replace the tape.
Thanks.
Hi DaveJ,
Have you stopped by your dealership so they can take a look? Ford certified techs are great at tracking down and resolving issues like this one. Let me know how it goes!
Tang wrote:Apparently the glass hinges on my Escape were worked on at one time when I ran this complaint by the dealership, but they also had to readjust the locking mechanism on the liftgate itself on my Escape.
Domain wrote:Not related, but lubricate your liftgate glass as well. That one was giving me grief recently, and was silenced by the addition of black lithium grease. May also prove availing for the liftgate latch assembly as well.
Thanks for sharing your experience and suggestions, Tang and Domain! I'm sure DaveJ appreciates it. :)
Crystal
FordService
Yes, a real, verified Ford Customer Service Representative
E-C LEVEL 6
Postby patsfan1704 - September 1st, 2014, 2:45 am
DaveJ did you ever find a permanent solution for this?
Mine is doing the same thing. How do you adjust the lock mechanism?
patsfan1704
E-C LEVEL 3
Postby Barks507 - September 1st, 2014, 1:14 pm
I went through this issue a few months ago. I ripped everything apart then read an easy solution somewhere on line. Wrap a piece of sticky backed velcro around the post that the lift gate catches on when closed. Seemed to have worked.
Barks507
My vehicle: 2009 Ford Escape 4cyl
Postby underthetire - September 1st, 2014, 7:21 pm
Mine had a rattle and creaking noise going over speed bumps etc. Dealer replaced with a new latch assembly and no more noise at all. I believe its a newer version than the original.
underthetire
E-C LEVEL 8
My vehicle: 2009 xlt sun and sync 2.5
My vehicle's name: Money saver
Postby ExplorerTom - September 1st, 2014, 8:29 pm
Barks507 wrote:I went through this issue a few months ago. I ripped everything apart then read an easy solution somewhere on line. Wrap a piece of sticky backed velcro around the post that the lift gate catches on when closed. Seemed to have worked.
Mine is squeaky when it's cold. I wrapped some black electrical tape around the post for mine and it stopped. Course now the tape has melted off but it still doesn't squeak.
ExplorerTom
E-C LEVEL 6
My vehicle: '06 Mariner & '12 Escape
Postby gman1868 - September 2nd, 2014, 2:13 am
As per a suggestion I read on the forum a while back, I wrapped the post a few times with blue painters tape and the rattle disappeared.
Don't Phase me Bro!
gman1868
E-C LEVEL 1
Postby DaveJ - September 3rd, 2014, 4:10 pm
patsfan1704 wrote:DaveJ did you ever find a permanent solution for this?
I first tried wrapping the post with electrical tape. Although it stopped the rattle, it didn't last long. I then wrapped it with metal duct tape and sprayed it with a little lithium grease. This seems to work pretty well and lasts longer than the electrical tape.
I would rather just get it fixed so someday if the dealer has a new designed post or latch.
DaveJ
E-C LEVEL 3
Next
Users browsing this forum: Google Adsense [Bot], iLoveMyExploder, jfs 1232, MSNbot Media and 54 guests
