Common problems
Re: Common problems
Postby Surfscape - June 6th, 2008, 9:05 am
Does this magic elixer has a brand name? Sounds like we all could use it.
2004 Supercharged AWD Ford Escape Image OOORRRAAHHH - USMC
http://www.cardomain.com/ride/1474843
Surfscape
Supercharged Moderator
E-C LEVEL 6
My nickname: Surfy
My vehicle: 04 AWD XLT
My vehicle's name: Surfscape
Re: Common problems
Postby CrashNburn - June 6th, 2008, 1:50 pm
just goto a shop, non dealer and ask for some shudder stop for a ford.
2007 Ford Freestyle Limited AWD fully loaded, Silver, Black leather.
2004 Ford Escape True Blue Clearcoat Metallic
added: privacy tint, step bars, vent visors, front mud flaps, velcro DVD in the rear for my munchkins
upgrades: Toyo Open Country AT's, Fram Air, NAPA oil, Castrol Syntex. RIP
2005 CBR600F4i.Bar end mirrors, Smoked Windshield, LED flush mounts, mudflap removed. wifes bike now
2001 CBR929rr stock.
CrashNburn
E-C LEVEL 6
My vehicle: 2004 XLT
My vehicle's name: daughter calls it the trucklet
Grinding noise emanating from a wheel
Postby stone - August 18th, 2008, 9:02 am
It is possible that the wheel bearings need to be replaced.
stone
My vehicle: 06 Ford Escape XLT 4X4
My vehicle's name: Little Tonka
Re: Common problems
Postby RyanRage - June 7th, 2009, 6:46 pm
How about the door handles sticking a little and being tough to open?
Also, I know the wheel bearings go on them a bit quicker than normal.
RyanRage
My nickname: Rage
My vehicle: 2001 Ford Escape XLT
My vehicle's name: Tera
Re: Common problems
Postby Squishy - June 7th, 2009, 7:09 pm
That's the first time I've heard of either of those. My door handles do stick sometimes, but that's because of the nice coating of ice on it. I haven't noticed any of the mechanical door handle bits sticking on their own.
If you could write a short description of the problem with possible causes and known fixes, I will add it to my post.
The goggles, they do nothing!
The Garage:
Image Image Image Image
Squishy
Basket Case
E-C LEVEL 13
My nickname: Bev
Re: Common problems
Postby RyanRage - June 8th, 2009, 10:01 am
Door Handle Sticking
It feels like the door is locked and you just have to pull a little harder to get it open.. Not really a huge deal, but it can be a pain in the a** when you're tired. :lol:
Cause - Lack of lubricant in the handle to ease it while opening,
Easy Fix - Pull the interior door panel off and lube it.
Wheel Bearing
You'll get that low pitch rumble a bit like any other car.
Cause - No idea, unusualy fast wear.
Fix - Get a new one and put it on.
RyanRage
My nickname: Rage
Re: Common problems
Postby Squishy - June 8th, 2009, 4:41 pm
Okay, added to the list. :thumb:
The Garage:
Squishy
Basket Case
E-C LEVEL 13
My nickname: Bev
Re: Common problems
Postby RyanRage - June 9th, 2009, 6:36 am
I have 2 more for you as well, if you don't mind me nagging..
The sunroofs seem to be a problem for a lot of people. One of the tracks has a plastic component that breaks and only allows one side of the sunroof to up into a vant position.. And also won't allow the sunroof so slide open. I'm currently looking for a fix now. In the problems and solutions part of the forum, theres a bit about the sunroof there and a site that may have a kit to fix it for 150.
Rear Hatch actuator.. The hatch won't lock or unlock from the remote or power locks inside the vehicle. If It's locked, you have to peel off the top of the trim pannel and unlock it manualy. You can either order the assembaly from ford.. Or you can order an aftermatket actuator online.
RyanRage
My nickname: Rage
Re: Common problems
Postby Squishy - June 9th, 2009, 3:04 pm
Now those I have heard about. :)
Can you write a more detailed description on how you pull the trim panel back? Like what fasteners you removed, where you stuck your fingers to pull, and where the door lock actuator rod is? I think SOP for most shops is to drill a hole where the actuator rod is and then they have colour-matched caps to put in the hole - this is a much better alternative.
The Garage:
Squishy
Basket Case
E-C LEVEL 13
My nickname: Bev
Re: Common problems
Postby RyanRage - June 10th, 2009, 11:21 pm
:confused: Why would you want to deface such a nice vehicle?? I'll get pictures..
BECAUSE :pics: :lol:
RyanRage
My nickname: Rage
PreviousNext
Users browsing this forum: Google Adsense [Bot], mattc, The Pope and 25 guests
