2010 Axle Seal leak
Re: 2010 Axle Seal leak
Postby wptski - January 15th, 2010, 10:52 am
The seal and half-shaft have always been available alone but now the bushing is available without getting the case half. The TSB10-01-05 still lists the case half as it can be damaged also. The case half includes the seal and bushing.
Bill
What a waste of space, huge pictures of your cars, lists of cars you've own, addons, etc!
wptski
E-C LEVEL 5
Congratulations on reaching 750 posts!
My vehicle: '09 Ford Escape Limited, 4WD
Postby sinister mob - January 15th, 2010, 4:17 pm
The dealer called and said the vehicle is all set. Both seals replaced. We shall see how long they last. I will have them show me when I pick it up exactly where the seals are so I can check them. One sign of a return leak and it goes back.
2010 XLT/Metallic Sport Blue/Stone Interior traded for the New 2012 Jeep:
Image Image
For Sale:
Sub - http://www.escape-city.com/viewtopic.php?f=21&t=6124&p=104423&sid=1d66757af904032c428422acb6ebaf97#p104423
sinister mob
E-C LEVEL 5
My vehicle: 2010 XLT, 2.5L, AWD
My vehicle's name: Club Escape
Postby Tang - January 16th, 2010, 12:05 am
Let me know what they tell you... I will want to look for myself on my vehicle even though it's a 2009. I am getting an interior trim piece replaced under warranty (my second!)
Tang
E-C LEVEL 14
My vehicle: 09 ESC XLT 4WD V6
Postby 2010Escape - January 16th, 2010, 7:52 am
ophiruchus wrote:Let me know what they tell you... I will want to look for myself on my vehicle even though it's a 2009. I am getting an interior trim piece replaced under warranty (my second!)
Not to hijack the thread....but what needs to be changes through warranty in your interior. Thanks
2010Escape
E-C LEVEL 3
Postby Tang - January 16th, 2010, 12:39 pm
One of my rear trim pieces fell off when one of my buddies accidentally gave it his shoulder... and the dealership took that in as a warranty repair. The door for the sunglasses holder started cracking because I used it to hold my magnetic parking pass... and they just got the part to replace that a few days ago.
Shh! don't tell my dealership. :D
Tang
E-C LEVEL 14
Postby sinister mob - January 16th, 2010, 2:04 pm
They replaced the right and left front axle seals. That was it. The work order listed the seal replacement, cleaned the axles, checked for any wear and reassembled. Checked for leaks afterwards.
Image Image
For Sale:
sinister mob
E-C LEVEL 5
Postby Tang - January 16th, 2010, 7:35 pm
well, that's good news. hopefully you won't be back in again for the same repair! I better tell my agent that I want a more thorough inspection at my 15k service...
Tang
E-C LEVEL 14
Postby kek7648 - January 21st, 2010, 11:58 am
I have a 5 month old 2009 Escape 4 cylinder and the axle seal started leaking. This then began a chain of events that are as follows:
Engine started bucking, no engine light went on
Engine would not shift from 1st to 2nd smoothly- although it is automatic transmission
front driver side axle needed to be completely replaced due to axle seal leaking
took car in and 2 WEEKS LATER, THEY CANNOT FIND THE BUSHING NEEDED TO DO THE REPLACEMENT
they will not pay for a rental and they do not have a loaner system at this dealership. the car is on the lift, no front tires and the engine is in pieces.
I received confirmation dealership this is a wide spread issue and the parts are hard to come by since they are in the midst of a 'remodel'.
I will never get another ford and if anyone buys this car, good luck!
kek7648
Postby sinister mob - January 21st, 2010, 12:29 pm
kek7648 wrote:I have a 5 month old 2009 Escape 4 cylinder and the axle seal started leaking. This then began a chain of events that are as follows:
Ouch. Not a terrific 1st post huh? I will keep checking those seals. It is either a.) fixed and no leaks or b.) not fixed and it keeps leaking. If it keeps leaking I will go back 50 times if needed. Each and everytime I go back I will demand a rental or loaner of some sort. I paid for an extended warranty and I WILL get a working vehicle one way or another.
Image Image
For Sale:
sinister mob
E-C LEVEL 5
Postby jonas1022 - January 21st, 2010, 12:46 pm
Sorry for your new car issues. :(
Nothing like this with our car, or any Ford I've ever had, front or rear drive. :shrug:
I'll keep going back to Ford. Better reliability than just about any other car on the road, so your options are limited. Just my opinion based upon big numbers and facts. For comparisons sake. CR, says it's even better than the site below does.
No rah-rah blather, just some info. Check this thread out: viewtopic.php?f=3&t=548&p=80988&hilit=members+numbers#p80988
aka "David"
“Love the people who treat you right. Pray for those who don't”
jonas1022
Award-Winning Bullitt Tribute Moderator
My nickname: aka David
My vehicle: 01 Mustang Bullitt, 08 Tribute
PreviousNext
Users browsing this forum: ccaweber, Tom Senyitko, wptski and 33 guests
