Instrument panel dead
Postby moldham09 - September 16th, 2010, 4:23 pm
So i was driving along the other day and my whole instrument panel died along with my radio and power mirrors
i thought it was the fuse so i went and checked found out it was #7
went to replace the fuse and it blew two new ones immediately
Im thinking that it is a short but i dont know where it could be at?
Im sussposed to go camping with my E on tues and dont really have the $$ to throw it in the shop.
Any help is greatly appreciated
btw this is me going 0 :wall:
moldham09
My nickname: Matt
My vehicle: 2006 Ford escape
Re: Instrument panel dead
Postby jpark - September 16th, 2010, 4:41 pm
Do you have a factory sound system, or an aftermarket system?
If it's an aftermarket system, my guess is that someone installed it with exposed or pinched wiring somewhere.
2016 Ford Escape Titanium 4WD, Magnetic Metallic, Charcoal Heated Leather, new 9/23/2015
- 2.0L EcoBoost I4, 6-speed auto, 301A, Sync 3/Sirius/HD, Panoramic Roof, Navigation
- Husky WeatherBeater 99741/23741 mats, Ford factory splash guards
2008 Ford Fusion SE FWD, Black, Charcoal/Red leather, new 2/23/2008, still strong and trouble-free
- 2.3L I4, 5-speed auto, Sync, Sport Appearance/Moon 'N Tune/Ambient Lighting packages, Husky WB 98301 mats
2013 Ford Escape Titanium 4WD, Ruby Red Metallic, Charcoal Leather, new 11/2/2012, sold 9/23/2015
2010 Ford Escape Limited FWD, Black, Camel Leather, new 4/22/2010, sold 11/2/2012
2007 Ford Edge SEL Plus AWD, Blazing Copper Metallic, Charcoal Leather, new 6/18/2007, sold 4/22/2010
2005 Ford Escape Limited 4WD, Redfire Metallic, Pebble Leather, new 6/4/2004, sold 6/18/2007
jpark
E-C Administrator
My nickname: JP
My vehicle: 2016 Escape Titanium 2.0EB 4WD
Postby tang - September 16th, 2010, 5:03 pm
Oh weird, haha... the needles are pointing the same direction. I guess preliminary info like what jpark has asked is pretty relevant...
PM with wheel questions.
past: 09 Escape XLT V6 AWD
present: 15 Taurus SEL AWD
tang
E-C LEVEL 16
My vehicle: 09 ESC XLT 4WD V6
Postby moldham09 - September 16th, 2010, 8:32 pm
It is a aftermarket stereo system, and i thought that might have been a problem. So I went in and disconnected the wiring harness to the radio so now it is attached to nothing and that didnt solve the problem. :worry:
moldham09
My nickname: Matt
Postby NormH3 - September 17th, 2010, 8:34 am
to find a short, you almost have to disconnect one device at a time. of course you could always jumoer across the fuse and look for the smoke :) (not advised)
NormH3
E-C LEVEL 1
My nickname: Norm
My vehicle: 2005 Ford Escape XLS 2.3L 4WD
My vehicle's name: Bullseye
Postby C17chief - September 17th, 2010, 9:32 am
NormH3 wrote:to find a short, you almost have to disconnect one device at a time. of course you could always jumoer across the fuse and look for the smoke :) (not advised)
def not recomended as you could potentially take out more stuff with it resulting in more costly part replacements instead of just wiring repair. Only good way is shooting wires with a multimeter, but that can be pretty time consuming not to mention beyond a lot of people's ability if they dont know how to propperly read schematics and use a multimeter to ohm out wires and such. Jump it till it smokes could be a big shortcut, but could also be a big backfire just as easily.
C17chief
E-C LEVEL 1
Postby jpark - September 17th, 2010, 9:39 am
I thought this might be an aftermarket installation problem.
My guess is that your short is somewhere between the connector and however the connector wiring was spliced into the factory wiring.
Take out the head unit, disconnect the connector, and look at how each wire is connected to that connector. I'm sure you'll find the problem.
jpark
E-C Administrator
My nickname: JP
Postby moldham09 - September 17th, 2010, 10:27 am
thanks norm but id rather not break anything else :(
and chief, iv already started with my multi. Im actually pursuing a degree in electrical engineering so wiring and schematics are not a problem for me. thanks for the tip
jpark wrote:I thought this might be an aftermarket installation problem.
I went back in and checked the wiring and saw a few wires that were slightly exposed so im thinking that they might of touched and caused a spark causing the fuse to blow.
Im now off to autozone to grab another handful of 10A mini fuses
thanks for the help so far y'all. :)
moldham09
My nickname: Matt
Postby NormH3 - September 17th, 2010, 10:38 am
if you wanted to verify the fix before blowing more fuses, you could check between the cold side of the fuse holder (fuse removed of course) and ground with your multi meter to see if the short still exists. Good luck with your studies.
NormH3
E-C LEVEL 1
My nickname: Norm
Postby NormH3 - September 17th, 2010, 10:39 am
it was a tongue in cheek comment as indicated by the happy face.
NormH3
E-C LEVEL 1
My nickname: Norm
Next
Users browsing this forum: Andfroe, Google [Bot], JohnCT, wptski and 50 guests
