Rapid Turn Signal?
Rapid Turn Signal?
Postby schufitz - October 12th, 2010, 9:13 pm
While driving to work today I noticed my left turn signal was blinking about twice as fast as normal. The right signal and hazards seem 'normal'. Is this just someting to change under the dash where the 'clicking' noise seems to come from. It's a '09 XLT with ~11,000 miles.
Thanks.....
Sangria Red with Sun & Sync, Cargo Package, Integrated Side Steps & 17" Chrome Clad Wheels
schufitz
My vehicle: '09 XLT V6
Re: Rapid Turn Signal?
Postby zippyworld - October 12th, 2010, 9:17 pm
You probably have a burnt out bulb on the left turn circuit.
zippyworld
E-C LEVEL 1
Postby schufitz - October 12th, 2010, 9:24 pm
Just went to the garage to check if front & rears were working, they were, but now left is normal again. ????
schufitz
Postby Four_Eyes - October 12th, 2010, 10:41 pm
Probably the bulb. My guess is, it's toast, but for the time being, the element moved so that it's (for the time being) completing the circuit. Since the element is (probably) no longer attached properly, when it shifts, the bulb will die out again. You'll have to visually inspect them.
Four_Eyes
E-C LEVEL 3
My vehicle: 2005 Escape XLT V6 4x4
My vehicle's name: Escape!....what else?!
Postby 08HybridOK - October 12th, 2010, 10:47 pm
Four_Eyes wrote:Probably the bulb. My guess is, it's toast, but for the time being, the element moved so that it's (for the time being) completing the circuit. Since the element is (probably) no longer attached properly, when it shifts, the bulb will die out again. You'll have to visually inspect them.
A visual may not help, just had the same thing happen, left rear was out, bulb looked good tho.
Replace with # in the book, previous post someone found it should last longer then the # I took out (sorry can't recall #'s). Mine was rear.
2008 Escape Hybrid FWD
Ice Blue w/Chrome Pkg
Mods: Mud Flaps, Cargo floor mat, Keyless Pad, Tint, Side Body Molding, Hybrid badge on sides, SCIIxG
Picture Page
2000 Expedition Eddie Bauer
1965 Ford Falcon Futura
08HybridOK
E-C LEVEL 3
My vehicle: 2008 Ford Escape Hybrid FWD
My vehicle's name: Li'l Blue
Postby Four_Eyes - October 12th, 2010, 10:54 pm
I should have been more specific. Pull the bulbs and tap them with a finger. You want to make the element shake. If the element is disconnected, it will fall out of position and you'll find the burned out bulb.
Four_Eyes
E-C LEVEL 3
Postby SUVord - October 13th, 2010, 6:52 am
As mentioned above, bulb or bulbs is the problem.
They are so cheap it is worth changing them for peace of mind.
Be cool-Be nice-LEEDS UNITED
SUVord
First poster on E-C's new server
E-C LEVEL 10
My nickname: Jacindo
My vehicle: Ford Maverick 3l XLT
My vehicle's name: Argos
Users browsing this forum: Google Adsense [Bot], mattc, The Pope and 27 guests
