Liftgate won't open
Liftgate won't open
Postby zboow - January 20th, 2011, 5:21 pm
I have a 2008 Limited and the button to open the rear liftgate doesn't work. I can still open the glass but that's it. Is there anything I can do short of taking off (and almost certainly breaking in the process) the interior panel to get the gate open? Thanks all
zboow
Re: Liftgate won't open
Postby zboow - January 20th, 2011, 6:11 pm
Ok I managed to get the panel off with the gate closed, I worked installing steros and starters for 2 years and really didn't think that was going to happen. Does anyone have a link to a wiring diagram? I plan now to install a new actuator (if that is indeed the problem) but I metered the wires, green has about 7V on it all the time, even when I hit the switch. Black doesn't ground when I hit the switch either.
zboow
Postby alpinder - January 23rd, 2011, 2:33 pm
Have the same vehicle and had the same problem. With mine the switch on the tailgate for operating the liftgate had water and crud in it and had shorted out which resulted in the hatch actuator no longer cycling. You can easily test for this problem by disconnecting the harness either coming into the liftgate (now that you have the panel off) or by removing the screws that hold on the panel containg the switches and license plate light and pulling the plug going to the liftgate switch and reconnecting it. If the switch is shorted the actuator will cycle every time you do that. Ford had a repair kit which included both the switch and the plug going to the switch as both get pretty corroded.
alpinder
Postby fotojack - January 23rd, 2011, 2:47 pm
And while you're in there replacing things, use dielectric grease on all the contacts you find. It'll save you a bunch of headaches in the future.
2005 Escape XLT 4WD V-6
Despite the high cost of 'LIVING'.......it's still very popular. ;) Get it? :)
fotojack
E-C LEVEL 3
My vehicle: 2005 Ford Escape XLT 4WD
Postby jeziorski_7 - January 25th, 2011, 2:18 pm
how do u know if it is the solenoid or the universal actuator ???????????
jeziorski_7
My vehicle: 2001 Ford escape XLT 4x4
Postby zboow - February 5th, 2011, 6:41 pm
problem was indeed the switch. got a replacement from Ford for $40
zboow
Postby lovetodrive2000 - December 18th, 2011, 2:53 pm
Anyone have photos of what parts to look at to fix this.... ours (2009) started acting up a week or two ago, now is almost impossible to get the hatch open.
Out of warranty... got 42k on it. :(
lovetodrive2000
Users browsing this forum: Bing [Bot], Google [Bot], mattc, The Pope and 28 guests
