2011 ESCAPE XLT Cabin Air Filter Install
Postby jenels4 - March 15th, 2011, 12:03 pm
I've been reading a few threads on ESCAPE-CITY about Ford Escapes. I came across numerous mentions that the cabin air filter is not installed at the factory, so I investigated it on my brand new 2011 Escape. They are right, its not there, but it will be.
The following picture is the engine bay of a 2011 FORD Escape XLT 2.5cc . The cabin air filter location is on the extereme left of this picture upnear where the hood hinges from the body. The passenger side.
You have to remove 8 plastic screws from the cowl, which is one piece from the driver to passenger side. Then lift up the cowl, which will reveal another hatch that you must lift up to gain access to the cabin air filter placement box.
Placement of the Cabin Air Filter: Auto Zone #CAF1844P (made in China) $22.00. Filter to me does not really "fit" in well, that could be because I told the salesperson I had a 2010 Ford Escape 2.5 engine and there may have been a design change from 2010 to 2011. The cage for the filter seems flimsy and looks like chicken wire wrapped around a box. You can see the top and bottom tabs (4) that hold the cabin air filter hatch in place.
On the last picture, you'll notice two tabs just in front of the filter. Those are the tabs that keep the hatch for the cabin air filter closed. You have to pull towards the engine to "disengage" them. You'll have to be aggressive to get them to open and the whole tray will move like its going to break, but doesn't.
jenels4
My nickname: FlyingJ
My vehicle: 2011 XLT ESCAPE Tuxedo/Charcoa
My vehicle's name: SOCKSII
Re: 2011 ESCAPE XLT Cabin Air Filter Install
Postby slavrenz - March 15th, 2011, 12:39 pm
Good write-up! I have a 2010 XLT 2.5L, and I agree that the filter does not fit well at all (and mine is from the dealer). The filter doesn't really rest in a formed casing - it just sort of rests on some molded plastic that slopes downward.
What I'm curious about, is why your vehicle has pink coolant in it - did Ford switch to a new kind of coolant for 2011? Mine is gold/green.
slavrenz
E-C LEVEL 6
My nickname: Steve
My vehicle: 2010 Ford Escape XLT I4
Postby hutchej - March 18th, 2011, 9:21 am
Did they include the cabin filter on the 2011 LTD?
Jon Hutcheon
2011 Ford Escape LTD 4wd
2007 Ford Explorer LTD 4x4
2005 Ford Explorer V8 EB 4x4
hutchej
E-C LEVEL 1
My nickname: thehutch
My vehicle: 2011 Ford Escape LTD 4wd
Postby normkol - March 18th, 2011, 12:58 pm
Good write up and good pictures.
You really don't have to remove all 8 fasteners, the 4 on the passenger side should give you adequate access.
I had a 2002 Tribute, and the cabin filter there fit like it was made for it.
Why they went to this installation on later models, like my 2010, is beyond me. It was like a junior engineer was let loose and no one was supervising. The filter simply doesn't fit, and I used the oem Motorcraft.
BTW, the filter from Rock Auto is only about $13, for the Motorcraft.
Norm
2010 Mariner Premier V6 4x4
Steel Blue/Stone
normkol
E-C LEVEL 1
My vehicle: 2010 Mariner Premier V6 AWD
Postby jerrybb - March 21st, 2011, 5:04 pm
I also read about changing the filter, so I opened the compartment on my 2010 and found NOTHING. Just some dirt and twigs down in there, so I also got one at Pep Boys for $20 and installed it. A little sloppy as you said, but at least it's there now and seals ok I think. I'm the second owner but the car has only 16k on it, and I'll bet the PO never took it out, it came that way from the factory.
jerrybb
Postby Squishy - March 21st, 2011, 5:37 pm
I'm pretty sure Escapes still don't come with a cabin air filter from the factory. The first gen models never did, for sure.
The goggles, they do nothing!
The Garage:
Image Image Image Image
Squishy
Basket Case
E-C LEVEL 13
My nickname: Bev
Postby jeziorski_7 - March 23rd, 2011, 11:55 am
yeah i have a 2001 ford escape and when i checked mine it wasnt there either. Canadian tire had it for like 22 bucks so it was really easy to instal and you could feel a diffrence in the car.
jeziorski_7
My vehicle: 2001 Ford escape XLT 4x4
Postby barhoc11 - May 4th, 2011, 9:08 pm
Just curious, have any of you noticed a difference after installing the cabin air filter? I want to do this but it seems like since this is such an odd fit, maybe its not even worth the hassle.
barhoc11
Postby tang - May 4th, 2011, 10:41 pm
Canada Panda wrote:I'm pretty sure Escapes still don't come with a cabin air filter from the factory. The first gen models never did, for sure.
Question: WHY?!
PM with wheel questions.
past: 09 Escape XLT V6 AWD
present: 15 Taurus SEL AWD
tang
E-C LEVEL 16
My vehicle: 09 ESC XLT 4WD V6
Postby SUVord - May 5th, 2011, 5:18 am
Question: WHY?!
They just forgot!!!
Someone must have told them, since my 2004 had one.
Be cool-Be nice-LEEDS UNITED
SUVord
First poster on E-C's new server
E-C LEVEL 10
My nickname: Jacindo
My vehicle: Ford Maverick 3l XLT
My vehicle's name: Argos
Next
Users browsing this forum: Andfroe, Google [Bot], JohnCT, wptski and 50 guests
