1 - 8 of 8 Posts
howdy, Hn r makes a 1 inch front and rear achieved with new springsi have only seen this advertised through the tire rack, and Canuck motorsports makes a 1.25 front and rear that is also new springs. I have the canuck front lift just have not had the time to install yet. BDS used to make a 2", but they have since stopped. here are the links
http://www.canuckmotorsports.com/
http://www.tirerack.com/suspension/susp ... perfCode=P
hope this helps
Dale :rockon:
BDS made a 2" inch kit but seems to have stopped production on them. There is a thread on here where we researched custom springs and a place could make the spings for less than the original BDS kit and even go higher as desired.
Problem is you can only go so high and then risk CV problems due to the drastic angle they run at under higher lifts.
thank you surfscape..do you know a link for the 2'' spring maker? 2'' would work nicely for me. i cruise on the beach a lot to surf fish and would like the 2'' and some bigger wheels and tires so i have a little more off road clearance. i see 1'' spring kits but id really like to get a 2'' lift if possible.
Thanks Surf. I think Im gonna keep it simple and do the 1.5'' canuckmotorsport springs and maybe some KYB shock and struts. That should help me a bit. As for your ride, am I reading your cation above the picture correct? Supercharged? Very cool. Where did you get the SC? How was it to install? Cost? I'll have to log in to cardomain to check out more about your ride. :D
Kenne Belle use to make a Supercharger kit for the 3.0V6, but again they have quit producing them. I guess just not enough demand, which sucks.
1 - 8 of 8 Posts
