Hey everyone,
I have been on this site reading many of the problems and found everyone to be quite knowledgeable, so I am hoping someone can help me with my issue..
I love Ford Escapes, and now that I have a decent job it was my goal to get an XLT before the winter sets in. I have been looking at gently used ones because so I don't immediately experience the "driven right off the lot" depreciation, yet also get a newer car that is under warranty.
I have been looking at an 09 XLT FWD. @ 17k miles and still under the bumper to bumper and powertrain warranties, it is priced very well at $17,900 and is in apparently great condition. The one caviat of the car is that it was previously a rental, albeit a one owner car, never in a wreck. I have been working a premature deal out on it over the phone with the salesman, and we were close to making a deal, after the test drive and an inspection (I'd already driven the same model XLT many times and new it's what I wanted). The only problem? The car is 4 hours away from where I live. I had a well reviewed mechanic in the area of where the car is go do an inspection on it for me and he found a transmission fluid leak. No big deal right?
The dealer was made aware of the issue by the inspector and notified me over the phone after they looked at it also that this was transmission fluid leaking from the left front axle through the axle seal. He said that the axle was not tightly in place and moved around and loosened the seal. He also told me that under the warranty, both the axle and the seal would need to be replaced, and this would be no problem. Ok, I can handle that..
The next day, I get a call from the salesman informing me, "Well, I didn't want to make this call, but I feel like I should tell you... While replacing the left front axle and axle seal there was a problem that was discovered." The bushings in the transmission were shot and also needed to be replaced (not sure if it was one or several), but it was the bushing/s related to the transmission. The mechanic told him that the transmission would have to be somewhat disassembled and put back together, etc. with the new bushings, then the axle would be fixed. Although I don't know much about engines or cars, I do believe this is all resulting from the same problem and that the axle being loose also somehow damaged the transmission bushings, and I would think this resulted in other damage to the transmission, but I have no way of knowing. He also assured me there was no other damage resulting from this problem and that the other parts of the transmission were fine.
MY questions to all of you is, is this a normal problem with these 09 escapes? Looking through the internet I have seen some mention of the transmission in these reporting problems, but this just seems ridiculous. Also, for those of you who know about cars.. should I believe no other damage was likely done from the axle being loose to either the transmission, tires, engine, alignment, etc.? IS an escape with these replaced factory parts going to be similar to what it was like in newer condition? SINCE THE DEAL HAS NOT BEEN DONE YET, SHOULD I STAY AWAY?
Thanks
Thanks
