I am going to install a KW-AVX810 as soon as i get home. I need to clear up a couple of things.
1) Where do i get 12V constant as my instructions state connect the yellow wire "To a live terminal in the fuse block connecting to the car battery (bypassing the ignition switch) (constant 12 V)" How can I connect that to fuse box? Do I just pop in a fuse a connect the wire to the one end of the fuse?
2) The red wire goes to the ignition right???
3) Doing it as described I should keep the factory setting of delay of turn off, you know when you open the door the radio turns off and 10 minutes delay if door is not opened?????????????????????????
