04-004/02
2001-2002 Tribute - FLUID LEAKAGE FROM BRAKE RESERVOIR CAP
APPLICABLE MODELS
2001-2002 Tributes
DESCRIPTION
Some vehicles may exhibit fluid leakage from the brake reservoir cap. This may be caused by the insufficient sealing of the cap.
To improve the sealing, a new brake reservoir cap is available to prevent this condition.
Customers having this concern should have their vehicle repaired using the following procedure.
REPAIR PROCEDURE
1. Verify concern.
2. Install a new cap and turn it clockwise to secure.
NOTE:
Turn the cap until it completely stops.
^ Be aware of the direction of the label: the text part faces toward the front of the vehicle.
^ To prevent the label from peeling off wipe the leaked fluid or dust completely off the tank.
^ You can use brake cleaner to degrease if necessary.
PART(S) INFORMATION
EC37-43-55Y (New), EC01-43-55Y (Old) - Cap (Brake Fluid Reservoir Tank) - Qty. 1 - A
NOTE:
The new part can be used in place of the former part, but the former part cannot be used in place of the new part.
WARRANTY INFORMATION
Warranty Type: A
Symptom Code: 76
Damage Code: 97
Part Number Main Cause: EC37-43-55Y
Quantity: 1
Operation Number / Labor Hours: XX434XRX / 0.2 (Cap replacement and label attachment)
NOTE:
04-004/02
APPLICABLE MODELS
2001-2002 Tributes
DESCRIPTION
REPAIR PROCEDURE
1. Verify concern.
NOTE:
PART(S) INFORMATION
NOTE:
Warranty Type: A
Symptom Code: 76
Damage Code: 97
Quantity: 1
NOTE:
