MAKE/MODELS: Ford/Escape
MODEL/BUILD YEARS: 2001-2004
MANUFACTURER: Ford Motor Company
NHTSA CAMPAIGN ID NUMBER: 07V156000
MFR'S REPORT DATE: March 30, 2007
COMPONENT: Service Brakes, Hydraulic: Antilock: Control Unit/Module
POTENTIAL NUMBER OF UNITS AFFECTED: 446460
SUMMARY:
On certain sport utility vehicles equipped with Antilock Brakes (ABS), the ABS module connector may have missing or dislodged wire seals. This condition could allow contamination to enter the module connector, creating a potential for an electrical short.
CONSEQUENCE:
An electrical short might cause an ABS malfunction that would illuminate the ABS warning light, and in some cases, the module may overheat resulting in burning odor, smoke, and/or fire. This condition could occur either when the vehicle ignition switch is in the off position or while the vehicle is being operated.
Remedy:
Dealers will inspect the wire harness connector to the ABS module for missing or dislodged wire seals, and repair or replace the harness connector as appropriate. The dealer will also inspect the connector on the ABS module and replace it if it is found to be corroded or damaged. The recall began on April 23, 2007. Owners may contact Ford at 1-800-392-3673.
NOTES:
Ford recall No. 07S51. Customers may also contact The National Highway Traffic Safety Administration's Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to http://www.safercar.gov.
SUMMARY:
CONSEQUENCE:
Remedy:
NOTES:
