1 - 2 of 2 Posts
I4 Zetec:
Engine Mount: Specifications
Engine MountGround Wire Nut (Engine)80 in-lb
Ground Wire Nut (Body)89 in-lb
Bolt/Nuts41 ft-lb
Lower Bracket Bolts37 ft-lb
Engine Mount: Service and Repair
Special Tool(s)
Removal and Installation
1. Install the special tool.
2. Disconnect the ground strap.
3. Remove the engine mount upper bracket.
4. Disconnect the ground wire.
5. Disconnect the power steering line bracket.
6. Disconnect the power steering line bracket and position the line aside.
7. Remove the engine mount.
8. To install, reverse the removal procedure.
Parts
OEM Part
Price (Q1 2009)
Front Mount
Manual TransYL8Z-6038-BA
45.32​
Auto TransYL8Z-6038-AA
118.87​
Rear Mount
Manual TransYL8Z-6068-BA
172.81​
Auto TransYL8Z-6068-AB
95.16​
Labor
Replace
Skill Level
Mfg. Warr.
Std.
Front Mount
Right Side
B​
0.3​
0.4​
Left Side
B​
0.6​
0.7​
Both Sides
B​
0.7​
0.9​
Rear Mount
B​
0.5​
0.6​
V6 Duratec:
Engine MountBracket Bolts/Nuts76 ft-lb
LH Engine Support Insulator Bolts52 ft-lb
LH Engine Supoort Insulator Nut66 ft-lb
RH Engine Support Insulator Nut66 ft-lb
RH Engine Support Insulator Through Bolt and Nut89 ft-lb
Engine Mount: Service and Repair: Engine Support Insulators-Front, RH
Special Tool(s)
1. Remove the engine ground wire.
2. Using the special tools, support the engine.
3. Remove the A/C line bracket bolt and position the A/C lines out of the way.
4. Remove the engine support insulator bolt.
5. Remove the engine support tool.
(1) Remove the nut.
(2) Remove the bolts and insulator.
6. To install, reverse the removal procedure.
Parts
OEM Part
Price (Q1 2009)
Front MountYL8Z-6038-AA
118.87​
Rear MountYL8Z-6068-AB
95.16​
Labor
Replace
Skill Level
Mfg. Warr.
Std.
Front Mount
Right
B​
0.4​
0.6​
Left
B​
0.6​
0.8​
Both
B​
0.9​
1.4​
Rear Mount
B​
0.5​
0.6​
1 - 2 of 2 Posts
