1 - 20 of 21 Posts
Removal and Installation
The fuel filter is located under the left side of the body, between the front and rear doors.
WARNING: Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel-related component. Highly flammable mixtures are always present and may be ignited, resulting in possible personal injury.
:fire:
1) Relieve the fuel pressure.
* Remove the fuel pump relay from the Battery Junction Box (under the hood on the left side, C1051, shown below), then start the engine and wait for the engine to stop running.
2) Disconnect the battery ground cable.
3) Raise and support the vehicle.
NOTE: Place a suitable container below the fuel filter.
4) Disconnect the fuel lines to the fuel filter.
5) Loosen the clamp and remove the fuel filter.
NOTE: When the fuel lines have been disconnected, install new retaining clips.
6) To install, reverse the removal procedure.
I just did this today! thank you so much for this guide. The only issue I had was the fuel filter holds a crap load of gas and it sprayed/dripped all over. Luckily I was wearing my safety goggles :D
Did you get a Motorcraft filter or aftermarket? I'm curious if the one you installed had the correct clips.
The aftermarket fuel filters I've seen don't have the big clip & the auto parts stores around here don't carry the big clips.
Thanks.
So, I guess you reused your old clips because the Purolator filter didn't have any or they were the wrong size?
Personally, I'd prefer to use new clips, since plastic gets brittle over time. I installed a Fram fuel filter: it had two small clips. Since the auto parts store didn't sell the larger sized clip, I doubled up two smaller clips on the big clip end which fit fine & the filter was secure. I wrapped them in electrical tape as a just in case, although it was probably unnecessary.
Afterwards, I saw that you have a newer model, so your clips won't be that old. Someone w an older model who's been reusing the original clips (or doesn't really know how old they are), probably ought to use new ones. The shop manual says to replace them whenever the fuel lines have been disconnected.
My 08 doesn't have the same little white retainer clips holding the fuel lines to the filter. I removed the metal clips but can't get the dang lines off the filter now. Any tricks? I don't want to just "pull really hard" since I'm worried I'll rip off the coupler. :confused:
Never mind. :) After much more research (and disbelief that Ford went back to the style of filter I had on my '94 F150) I found a tool to remove the "quick connect" fuel lines. Note to self, quick connect is only connecting fast. . .it should further read: "painfully slow disconnect without proper tool, but really quick to connect after."
The previous poster talks about a disconnect tool. Whichk size did you use? Also this[YouTube][/YouTube] guide states 2001-2004. Is there any difference for 2005 +. I have a 2008 mariner 3.0 awd. Is pulling the fuel pump relay nessesary on this generation too?
Thank you.
Thank you.
You will always want to pull the fuel pump relay, start the car to get the fuel and pressure out of the line. If you do not...it will be a very messy and maybe dangerous job. As for the tool size, not sure, I was able to use a screw driver and pliers.
I just changed the FF on my taurus. The front end disconnected ok. The rear was more trouble. I use a screwdriver to pry it off, while still mounted with the chassis.
So mostly the same procedure.
So this guide could be expanded out to 2011 fitment ?
thesavo - Yesterday, 6:58 am
I just tried getting the lines off the filter in my 2008 Mariner 3.0L. I was using the "wrench" method. The lines would NOT pry off. I am going to HFT to pick up a set on Monday. I'll let you know.
Another 2008 owner here that has the same style filter and in the same location. I have the fuel line tools, (quick disconnect type) from my 90's Ford trucks I owned. Now I just have to get the filter, BRB LOL! :lol:
For anyone else it should be this one: http://www.autozone.com/autozone/access ... 46367_0_0_ at Autozone - Part Number: 25043
They have two tools, one is a 4-way and the other is the a smaller-sized 2 way, which is the one we need.
I did it and it was still a beeeatch even with the tool. You really have to jam the lip on the tool down into the tube-clasp-thing to get it to release.
I didn't try any of the cheaper plastic tools but I've gotta they would have to be at serious risk for breaking with the force you have to apply to get the line to disconnect.
1 - 20 of 21 Posts
