This is just a temporarily fix. I will post and more effi. way when i get my new lock and in and make manual with power lock together.
Pull back enough to insert you hand and go to the circle area and pull up on lock actuator
After you unlock and open the liftgate remove the four phillips screws
You can break the lock actuator arm off like did and run a coat hanger threw it like so
So you can lock and unlock until you can replace the actuator
Now put it back to together and and run the wire up next the window latch and just push down to lock and up to unlock
But leave the window up to test or leave the screws out to you can mod you to your likely
