Tools needed:
  • 19 mm socket (wheels, tie rod end retaining nut)[/*]
  • 98 ft-lb torque wrench (lug nuts)[/*]
  • Needle-nosed pliers (cotter pin)[/*]
  • Tie rod end remover (can substitute standard puller)[/*]
  • 15 mm open end wrench (tie rod)[/*]
  • Adjustable wrench (jam nut; should use an open ended wrench, but I did not have the correct size - looks like 24 mm)[/*]
  • 37 ft-lb torque wrench (retaining nut)[/*]
  • Permanent marker (indexing the tie rod)[/*]
  • Penetrating solvent (WD-40 is no good)[/*]
  • The Big Hammer(TM)[/*]
  • New tie rod end (not pictured)[/*]
  • Two jack stands and string (for alignment)[/*]
  1. Remove the wheels and throw a menacing glare at the bad tie rod end. :mad:
  2. Remove the cotter pin.
  3. Spray penetrant on both the jam nut and the castellated retaining nut.
  4. Draw a line along the top of the tie rod to allow you to keep track of how many turns you have made.
  5. Loosen the jam nut (turn clockwise to loosen). If the tie rod turns along with the jam nut, return the tie rod to the original position using the marker line.
  6. Loosen the castellated nut, but do not completely remove. This makes it easier to center the puller and won't allow the tie rod end to fly up into your face.
  7. Unscrew the tie rod end, spraying more penetrant if necessary. Count the number of turns you make so that you can get your alignment back into roughly the same setting.
  8. Clean any rust from the steering knuckle.
  9. Screw the new tie rod end onto the tie rod the same number of turns it took to remove the old one. Tighten the new castellated nut to 37 ft-lbs (50 N-m) and insert the cotter pin. Leave the jam nut loosened for now.
  10. Replace the wheel and tighten two to three lug nuts, then lower the car completely. Using two jack stands and a string, stretch the string across both the front and rear tires. Check that there are four contact points with the sidewall; raise the vehicle and adjust the tie rod as necessary. I needed a half turn clockwise to get my alignment into an acceptable setting.
  11. Tighten the jam nut to 33 ft-lbs (45 N-m), grease the tie rod end if there is a grease zerk, and get an alignment done.[/*]
Discussion Starter · #2 ·
Ah geez, I just caught the reflection in that last picture. My Canadian is showing... :blush:
