Removal and Installation
All vehicles
[elist=4][li]Disconnect the Evaporative Emission Canister Purge Valve and position it aside.[/li]
[/elist]All vehicles
[elist=5][li]Disconnect the master cylinder and position aside.[/li]
[li]Remove the brake booster.[/li]
[li]To install, reverse the removal procedure.[/li][/elist]
All vehicles
- Remove the brake pedal push rod cotter pin and washer.
[/*] - Remove the four power brake booster pushrod bracket nuts.
[/*] - Disconnect the brake pedal pushrod.
- Disconnect the cable locator.[/*]
- Remove the nuts.[/*]
- Position the evaporative emission canister purge valve aside.[/*]
- Remove the nuts[/*]
- Position the master cylinder aside.[/*]
- Disconnect the vacuum hose.[/*]
- Remove the brake booster.[/*]
Parts | OEM Part | Price (Q1 2009) |
