2.0 L Zetec
Crankshaft Rear Oil Seal
Special Tool(s)
Removal
1. Remove the flywheel.
2. CAUTION: Use care to avoid damaging the crankshaft sealing surface.
Using the special tool, remove the crankshaft rear oil seal.
3. Inspect the crankshaft rear oil seal area.
Installation
1. NOTE: Coat the rear oil seal area and the crankshaft rear oil seal lip with Super Premium SAE 5W-20 Motor Oil or equivalent meeting Ford specification WSS-M2C153-H.
NOTE: Make sure the crankshaft rear oil seal is on correctly and that the edges are not rolled over.
Using the special tools, install the crankshaft rear oil seal.
2. Install the flywheel.
Special Tool(s)
Removal
Installation
Parts | OEM Part | Price (Q1 2009) |
