1 - 1 of 1 Posts
Functionality (Duratec engine only)
With the ignition switch in the ON position, voltage is applied through the warning indicator I circuit 904 (LG/RD) to the voltage regulator. This turns the regulator on, allowing current to flow from battery sense A circuit 112 (BK/YE) to the generator field coil. When the engine is started, the generator begins to generate alternating current (AC) which is internally converted to direct current (DC). This current is then supplied to the vehicle's electrical system through the output (B+) terminal of the generator.
Once the generator begins generating current, a voltage signal is taken from the generator stator and fed back to the regulator internally. This voltage feedback signal (typically half the battery voltage) is used to turn off the warning indicator.
With the system functioning normally, the generator output current is determined by the voltage of the A circuit. The A circuit voltage is compared to a set voltage internal to the regulator, and the regulator controls the generator field current to maintain the correct generator output.
The set voltage will vary with temperature and is typically higher in cold temperatures and lower in warm temperatures. This allows for better battery recharge in the winter and reduces the chance of overcharging in the summer.
Battery Positive Output Circuit (B+) 36 (YE/WH)
The generator output is supplied through the battery positive output (B+) terminal on the back of the generator to the battery and electrical system.
I Circuit 904 (LG/RD)
The I (ignition) circuit is used to turn on the voltage regulator. This circuit is powered up with the ignition key in the RUN position. This circuit is also used to turn the charging system warning indicator on if there is a fault in the charging system operation.
A Circuit 112 (BK/YE)
The A circuit or battery sense circuit is used to sense battery voltage. This voltage is used by the regulator to determine generator output. This circuit is used to supply current to the generator field (rotor). The amount of current supplied to the rotor will determine generator output.
1 - 1 of 1 Posts
