1 - 1 of 1 Posts
TSB 04-25-13
12/27/04
SERVICEABILITY OF INSTRUMENT PANEL REGISTER VENTS
FORD:
2001-2005 Escape
2005 Escape Hybrid
MERCURY:
2005 Mariner
ISSUE
Some 2001-2005 vehicles may exhibit instrument panel (IP) register vents that are difficult to adjust or are limited in their adjustability.
ACTION
Register vents for the IP center finish panel can now be ordered and replaced individually. Replacement of an entire center finish panel assembly to correct a register vent condition is no longer necessary. The IP outboard register vents can be replaced similarly without replacing the entire housing assembly, however, the outboard vent must be ordered as an assembly with the housing. Refer to the following Service Procedure.
SERVICE PROCEDURE
CENTER REGISTER REPLACEMENT
1. Remove center finish panel. Refer to Workshop Manual Section 501-12.
2. With center finish panel removed, release the register retention tabs and remove the register.
3. Replace register with Part Number YL8Z-19893-CAA left or YL8Z-19893-CAB right.
4. Reinstall the center finish panel.
OUTBOARD REGISTER REPLACEMENT
1. Tilt the vehicle's outboard register to the down most position. Pull the top of the register out until it is released from the housing.
2. Remove the new register from the service replacement register housing assembly (base # -19893-), as described in Step 1.
3. Snap the new register into the vehicle's existing outboard register housing.
Parts Block
PART NUMBER
PART NAME
YL8Z-19893-CAARegister (Center-Left)
YL8Z-19893-CABRegister (Center-Right)
-19893-Register And Housing (Outboard)
OPERATION
DESCRIPTION
TIME
042513ARegister Replace Right Outboard Vent Only
0.2 Hr.​
042513BRegister Replace Left Outboard Vent Only
0.2 Hr.​
042513CRegister Replace Both Center Vents (Includes Time To Remove And Install Center Finish Panel)
0.4 Hr.​
042513DRegister Replace All Vents (Includes Time To Remove And Install Center Finish Panel)
0.4 Hr.​
DEALER CODING
BASIC PART NO.
CONDITION CODE
19893
41​
1 - 1 of 1 Posts
