1 - 1 of 1 Posts
TSB: 01-032/05
2001-2006 TRIBUTE (3.0L ONLY) - DIAGNOSTIC TIPS FOR TROUBLESHOOTING COIL-ON-PLUG MISFIRE CONCERNS
NOTE:
This bulletin replaces 01-016/04. Please update your records accordingly.
BULLETIN NOTE
This bulletin supersedes the previous bulletin 01-016/04, issued on 8/6/04. The APPLICABLE MODEL (S)/VINS has been revised.
APPLICABLE MODEL(S)/VINS
2001-2006 Tribute (3.0L Engine only)
DESCRIPTION
Tributes with a V-6 engine that exhibit an engine misfire or rough running condition may be more accurately diagnosed using the optional Worldwide Diagnostic System (WDS) Coil-On-Plug (COP) Kit.
A high percentage of COP coils returned for warranty do not have a problem. The optional WDS Coil On Plug (COP) Kit available through MStore will provide more accurate diagnosis and help reduce replacement of non-defective parts. The WDS COP Kit (418-FS528) can be purchased through MStore.
The following material will detail the diagnostic steps using WDS to take the guesswork out of misfire diagnosis using the COP Kit. The following procedure is for cylinder specific misfires (P0301, P0302, P0303, P0304, P0305, P0306) and not random misfires. Random misfires have a different root cause and are not covered by this Service Bulletin.
Misfire Definition: A misfiring cylinder is lacking power relative to the other cylinders. The causes for a cylinder specific misfire could be fuel, spark, or mechanical problems.
REPAIR PROCEDURE
The misfiring cylinder must be identified through Self-Test misfire codes or through WDS Power Balance. Rule out mechanical engine problems and fuel system problems, then look at ignition problems (be sure to rule out any possible coil primary circuit issues). Once the above steps have been completed, and it is verified that the fault is in the secondary part of the ignition system, the oscilloscope procedure outlined in this SB can isolate the difference between a coil or spark plug problem.
Perform a thorough visual inspection. If no visible concerns are found use the following WDS tools for misfire diagnosis:
- Self-test (Check for codes first)
- Power Balance (Identify the cylinder of concern)
- Relative Compression (Rule out a possible mechanical issue)
- Fuel (Make sure fuel injectors are not leaking or restricted)
- Ignition (Make sure spark plugs and coils are working properly)
- Oscilloscope (Detailed signal analysis)
NOTE:
- Use the encyclopedia button in the lower left corner of the screen for detailed information on the WDS tool being displayed.
- If there is a self-test code identifying a particular cylinder then you just need to determine if it is a fuel, ignition, or possibly a mechanical problem. Proceed to Step 2 after running Relative Compression to rule out any mechanical issues. If there is no self-test code and the customer concern is a miss or rough running, proceed to Step 1.
1. (Select Toolbox Icon, then Powertrain, then Power Balance)
a. The cylinder specific miss has to be identified as shown in the example in Figure 1 in order to proceed with the remaining steps.
- If the miss does not occur at idle (in the service bay), try to brake torque the engine. This extra loading should reproduce the miss in the shop.
- If the miss cannot be reproduced during brake torque, select Relative Compression under Powertrain on WDS before going on a road test to rule out mechanical problems.
b. If Relative Compression shows a problem then the base engine issue must be serviced. If Relative Compression results are good (Figure 2), road test under as many different driving conditions as possible until the miss occurs on Power Balance. Some misses may be very intermittent so be patient and concentrate on steady load conditions. Once a cylinder dropout is identified proceed to Step 2.
2. (Select Toolbox Icon, then Powertrain, then Fuel System Test)
Run Fuel System Test on WDS to determine if there may be a fuel problem. After completing fuel Pressure/Leakdown test, select Injector flow to isolate a restricted injector.
- If the results of all the injectors are within specification as illustrated in figures 3, 4, and 6, then proceed to Step3.
Figure 3
Figure 4
Figure 6
- If any injector failures are detected as illustrated in figures 5 and 7, perform repairs as necessary.
Figure 5
Figure 7
3. (Select Toolbox Icon, then Powertrain, then Ignition System Test)
Run Ignition System Test on WDS to determine if there is an ignition problem. Look at both duration (DUR) and kilovolts (KV) and look for values that stand out from the rest as shown in Figures 8 and 9.
Figure 8
Figure 9
If either spark duration or peak KV on the Red Probe (Suspect Cylinder) are offset from the values displayed on the Black Probe (Known Good Cylinder) then the problem is in the ignition system. Rule out coil primary circuit issues before proceeding to coil secondary issues such as the spark plug , coil boot, or possibly the coil. Use the WDS Oscilloscope with the COP kit to determine if the issue is the coil or the spark plug.
NOTE: Note live display has to average ignition values because there is too much data to display. Make a capture to view each engine event without averaging. This can be helpful when the problem is intermittent. If miss is extremely intermittent and does not show up in ignition, proceed to Step 4.
4. (Select Toolbox, then Oscilloscope)
WARNING: Secondary ignition voltages are very high. Keep hands and tools away from the end of the coil that supplies the spark.
SET-UP: With the engine off, pull the suspect coil from the cylinder well and turn it upside down so the coil cannot spark to any other surface as shown in Figure 10. Wrap a clean shop cloth around the hard shell of the coil to help keep the coil propped up and stable.
CAUTION: The coil boot can be damaged if the coil sparks to another surface during this procedure.
Keep the coil connected to the harness and leave the WDS COP clip attached to the coil. Route the coil clip wire and cable away from the coil being tested as well as other coils to avoid noise interference. Disconnect the injector of the cylinder being tested so raw fuel is not washing the cylinder. This is a stress test for the coil. The type of waveform displayed on the oscilloscope will show whether a coil or the plug is the problem if all previous steps have been followed. Keep hands and tools away from the end of the coil that supplies the spark.
COP STRESS TEST PROCEDURE:
1. Go to the Oscilloscope Tool and select Channel 3, then select Auto, then select COPSTRESSTESTRED. This pre-configured setting will zoom-in on the peak firing of the coil being tested.
2. Start the engine and be sure the coil is not sparking to any surface.
- If the coil is sparking to other surfaces, turn the engine off immediately and readjust the coil so it cannot spark to any other surface.
3. Restart the engine and touch the Red Man icon to start the oscilloscope. All settings are pre-configured and no adjustments are necessary.
4. Compare the waveform you get with the examples provided in Figures 11, 12, and 13). Figure 11 is a good waveform. If your waveform is similar to Figure 11 the coil is working correctly. Suspect the spark plug.
Figure 11
5. Figures 12 and 13 are examples of problem coils. Replace the coil if the waveform is similar to Figures 12 or 13.
Figure 12
Figure 13
6. The coil is causing the misfire when the peak firing appears like those shown in Figures 12 and 13. Notice the difference in the peak-firing signal when compared to the good peak signal in Figure 11.
7. Figure 13 shows a more dramatic fault in the peak failure. Most root causes of misfire issues can be identified quickly using the steps outlined above. Some misfire issues can be difficult making the oscilloscope an important part of your diagnostic toolbox.
1 - 1 of 1 Posts
