To remove the two-piece fender molding around the front wheels:
1) Remove the splash shield inside the front fender.
2) Remove the visible screws around the inside lip of the larger fender molding and the smaller molding on the front bumper cover.
3) Remove the hidden retainer under the lowest part of the larger molding.
4) From inside the fender and bumper cover, push the spring-clip retainers outward and remove the moldings. Do not try to pull the molding away from the fender or bumper cover instead of releasing the retainers.
To install, reverse the installation procedure. Rear wheel moldings are similar, except for the splash shield removal.
