Removal and Installation
1) Remove the rear door trim panel. See viewtopic.php?f=28&t=21
2) Position the watershield aside.
3) Position the rear door glass top run aside.
* Remove the 2 bolts.
- To install, tighten to 8 Nm (71 lb-in).
* Position the rear door glass top run aside.
4) Loosen the 2 exterior door handle reinforcement screws until the exterior door handle reinforcement slides free.
5) Remove the exterior door handle cover.
* Pull the exterior door handle.
* The front of the cover must be released prior to removing the cover.
6) Remove the exterior door handle by sliding the handle towards the rear of the vehicle.
7) Remove the 2 exterior door handle seals.
8) Disconnect the exterior door handle actuating rod.
* Open the clip.
* Disconnect the actuating rod.
9) Slide the exterior door handle toward the front of the vehicle and remove the reinforcement.
10) To install, reverse the removal procedure.
* Open the clip.
