(click on thumbnails to expand)
Fog Lamp Bulb: Service and Repair
FOG LAMP BULB
Removal and Installation
WARNING: The halogen fog lamp bulb contains gas under pressure. The bulb may shatter if the glass envelope is scratched or if the bulb is dropped. Handle the bulb carefully. Grasp the bulb only by its base. Avoid touching the glass envelope. Failure to follow these instructions may result in personal injury.
CAUTION: The fog lamp bulb should not be removed from the fog lamp until just before a new bulb is installed. Removing the bulb for an extended period of time may affect fog lamp bulb performance. Contaminants may enter the fog lamp where they can settle on the lens and reflector. Never turn on the fog lamps with the bulb removed.
NOTE: Make sure the headlamp switch and the ignition switch are in the OFF position.
1. With the vehicle in NEUTRAL, position it on a hoist.
2. Remove the 4 front fender splash shield bolts.
- To install, tighten to 5 Nm (44 lb-in).
3. Remove the 4 front fender splash shield pin-type retainers.
- Position the front fender splash shield aside.
4. Disconnect the fog lamp bulb electrical connector.
5. Rotate the fog lamp bulb counterclockwise and remove the fog lamp bulb.
6. To install, reverse the removal procedure.
Turn Signal Bulb: Service and Repair
SIDE LAMP/FRONT TURN SIGNAL LAMP BULB
REMOVAL
1. Remove the wheel and tire.
2. Position the inner fender well aside.
(1) Remove the bolts.
(2) Remove the pin-type retainers.
(3) Remove the screw.
(4) Position the inner fender well aside.
3. Remove the lamp socket from the lamp assembly.
4. Remove the bulb.
INSTALLATION
1. To install, reverse the removal procedure.
FOG LAMP BULB
Parts | OEM Part | Price (Q1 2010) |
Fog Lamp Bulb | YL8Z-13466-BB | 18.73 |
REMOVAL
4. Remove the bulb.
INSTALLATION
