NOTE: Escape shown, Mariner and Tribute similar.
Item - Part Number - Description
1 - N806427-S36 - Interior door handle bezel screw
2 - 7822620 - Interior door handle bezel
3 - W703268-S424 - Door handle cup screw
4 - 78237W10 - Front door trim panel screw cover
5 - W703268-S424 - Front door trim panel screw
6 - W706476-S424 - Front door trim panel screw
7 - 7823942/7823943 - Front door trim panel
Removal and Installation
1) NOTE: LH side shown; RH side similar.
* Disconnect the battery. For additional information, refer to Section 414-01 .
2) Open the cover, remove the screw and the interior door handle bezel.
3) Remove the door handle cup screw.
4) Remove the front door trim panel cover and screws.
5) Remove the front door trim panel by unsnapping the plastic pins on the panel from the plastic anchors in the door.
6) Disconnect the electrical connector.
7) To install, reverse the removal procedure.
