1 - 8 of 8 Posts
TSB 09-6-5
04/06/09
NOISE - FRONT STRUT AREA
FORD:
2001-2009 Escape
2005-2009 Escape Hybrid
MERCURY:
2005-2009 Mariner
2006-2009 Mariner Hybrid
ISSUE
Some 2001-2009 Escape, 2005-2009 Escape Hybrid, Mariner and 2006-2009 Mariner Hybrid vehicles may exhibit a pop, rub, grunt, squeak, and/or creak noise from the front strut area during slow, lock-to-lock turns such as parking maneuvers. Vehicles built on or before 1/13/2009 may also exhibit a clunk, crunch, thump, and/or knocking noise from the front strut area while driving over a series of bumps and/or rough roads.
ACTION
SERVICE PROCEDURE
  1. Using chassis ears on the front strut mounts is pop, rub, grunt, squeak, creak, clunk, crunch, thump, and/or knocking noise present from the front strut area during slow parking lot type maneuvers?
    • No - Procedure does not apply, proceed with normal Workshop Manual (WSM), Section 204-00 diagnostics.[/*]
    • Yes on turns - Boot may be binding, go to Step 2 Dust Boot Greasing Procedure.[/*]
    • Yes over bumps (built on or before 1/13/2009) - Go to Step 3 Dust Boot Replacement Procedure and install new dust boot designed for this concern.[/*]
    • Yes over bumps (built after 1/13/09) - Procedure does not apply. Proceed with normal WSM, Section 204-00 diagnostics.[/*]
  2. Dust Boot Greasing Procedure.
    • Raise the vehicle per WSM, Section 100-02.[/*]
    • Reach through the spring and pull the strut dust boot and jounce bumper assembly straight down, out of the upper spring seat.[/*]
    • Apply Motorcraft(R) Silicone Brake Caliper Grease and Dielectric Compound.
      1. To the entire length of the chrome strut rod above the jounce bumper and 360 degrees around the rod.[/*]
      2. To the top and sides of the uppermost part of the dust cover.[/*]
    • Raise dust cover so that jounce bumper is accessible and apply 360 degrees to the jounce bumper itself.[/*]
    • Slide the dust cover and jounce bumper upward into its original location on the strut.[/*]
    • Repeat the procedure on the other side of the vehicle.[/*]
  3. Dust Boot Replacement Procedure (vehicles built on/before 1/13/2009).
    • Remove front strut per WSM, Section 204-01.[/*]
    • Disassemble front strut and replace dust boot with latest level part per WSM, Section 204-01.[/*]
    • Apply Motorcraft Silicone Brake Caliper Grease and Dielectric Compound.
      2. To the top and sides of the uppermost part of the dust boot.[/*]
      3. Apply 360 degrees to the jounce bumper itself.[/*]
    • Assemble front strut and install per WSM, Section 204-01.[/*]
PART NUMBER​
PART NAME​
9L8Z-18A179-A
XG-3-A
Strut Dust Boot Front Strut Motorcraft® Silicone Brake Caliper Grease and Dielectric Compound
OPERATION
DESCRIPTION
TIME
090605A​
2001-2009 Escape, 2005-2009 Escape Hybrid, Mariner, 2006-2009 Mariner Hybrid: Apply Grease Following Service Procedure. Includes Time to Evaluate Noise With Chassis Ears and Road Test (Do Not Use With 1007D, 18124A)
0.7 Hr.​
090605B​
2001-2009 Escape, 2005-2009 Escape Hybrid, Mariner, 2006-2009 Mariner Hybrid: Replace The Strut Dust Boots, Apply Grease FOllowing Service Procedure. Includes Time To Evaluate Noise With Chassis Ears and Road Test Can Be Claimed With Operations C And D (Do Not Use With 1007D, 18124A)
1.5 Hr.​
090605C​
2001-2009 Escape, 2005-2009 Escape Hybrid, Mariner, 2006-2009 Mariner Hybrid: Check Caster, Camber and Toe-In Can Be Claimed With Operation B And D (Do Not Use With 2001B, 2001B1, 2001B5, 2001B8, 2219D, 2219D2, 3185B, 3001A, 3001A6F)
0.6 Hr.​
090605D​
2001-2009 Escape, 2005-2009 Escape Hybrid, Mariner, 2006-2009 Mariner Hybrid: Correct Caster, Camber And Toe-In Can Be Claimed With Operation B And C (Do Not Use With 2001B, 2001B1, 2001B5, 2001B8, 2219D, 2219D2, 3185B, 3001A, 3001A6F)
0.6 Hr.​
DEALER CODING
BASIC PART NO.
CONDITION CODE​
18A179
07​
Discussion Starter · #2 ·
Bulletin No: 02-003/09
Last Issued: 05/07/2009
Subject:
NOISE FROM FRONT STRUT AREA
APPLICABLE MODEL(S)/VINS
2001-2006 and 2008-2009 Tribute
2008-2009 Tribute Hybrid
DESCRIPTION
Some vehicles may exhibit a pop, rub, grunt, squeak, and/or creak noise from the front strut area during slow, lock-to-lock turns such as parking maneuvers. Vehicles built before Jan. 13, 2009 may also exhibit a clunk, crunch, thump, and/or knocking noise from the front strut area while driving over a series of bumps and/or rough roads.
Customers having this concern should have their vehicle repaired using the following repair procedure.
REPAIR PROCEDURE
  1. Using chassis ears on front strut mounts, inspect for a pop, rub, grunt, squeak, creak, clunk, crunch, thump, and/or knocking noise from front strut area during slow parking lot type maneuvers.
    Inspection Result​
    Action Needed​
    No noise present​
    Procedure does not apply, proceed with normal Workshop Manual diagnostics.​
    Yes, noise present on turns​
    Boot may be binding, Proceed to Step 2, "Dust Boot Greasing" procedure.​
    Yes, noise present over bumps - (vehicle was built ON or BEFORE 1/13/09)​
    Proceed to Step 3, "Dust Boot Replacement" procedure and install a new dust boot designed for this concern.​
    Yes, noise present over bumps - (vehicle was built AFTER 1/13/09)​
    Procedure does not apply. Proceed with normal Workshop Manual diagnostics.​
  2. Dust Boot Greasing Procedure:
    • Safely raise vehicle on hoist.
    • Reach through spring and pull strut dust boot and jounce bumper assembly straight down, out of upper spring seat.
    • Apply locally sourced Silicone Brake Caliper Grease and Dielectric Compound.
      1. Apply to entire length of chrome strut rod above jounce bumper and 360 degrees around rod.[/*]
      2. Apply to top and sides of uppermost part of dust cover.
    • Raise dust cover so that jounce bumper is accessible and apply 360 degrees to jounce bumper itself.
    • Slide dust cover and jounce bumper upward into its original location on strut.
    • Repeat procedure on other side of vehicle.[/*]
  3. Dust Boot Replacement Procedure (vehicles built ON or BEFORE 1/13/2009):
    • Remove front strut according to MS3 online instructions or Workshop Manual (section 02-13 STRUT AND SPRING - FRONT REMOVAL/INSTALLATION).
    • Disassemble front strut and replace dust boot with new part.
    • Apply Silicone Brake Caliper Grease and Dielectric Compound.
      2. Apply to top and sides of uppermost part of dust boot.[/*]
    • Assemble front strut and install according to MS3 online instructions or Workshop Manual (section 02-13 STRUT AND SPRING - FRONT REMOVAL/INSTALLATION).
  4. Verify repair.[/*]
PART(S) INFORMATION
Part Number​
Description​
Qty.​
ZZD0-34-0A5​
Front Strut Dust Boot​
1​
WARRANTY INFORMATION
Apply Grease Only​
Front Strut Dust Boot Replacement / Apply Grease​
Warranty Type
A​
A​
Symptom Code
82​
82​
Damage Code
9A​
9A​
Part Number Main Cause
ZZD0-34-0A5​
ZZD0-34-0A5​
Quantity
0​
1​
Operation Number / Labor Hours:
YY577XRX / 0.7 Hrs. (Includes noise evaluation road test with chassis ears)​
YY578XRX / 1.5 Hrs. (Includes noise evaluation road test with chassis ears)​
[align=center]Check Camber Caster & Toe-In
Correct Camber Caster & Toe-In​
Warranty Type
A​
A​
Symptom Code
82​
82​
Damage Code
9A​
9A​
ZZD0-34-0A5​
ZZD0-34-0A5​
Quantity
0​
0​
YY579XRX / 0.6 Hrs.​
YY580XRX / 0.6 Hrs.​
NOTE:
  • This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair.[/*]
  • This repair will be covered under Mazda's New Vehicle Limited Warranty term.[/*]
  • Additional diagnostic time cannot be claimed for this repair.[/*]
Thanks! I am sure that everone here get something out of these updates, even though they may not post anything :clap:
thank you....i kept thinking that it was my tie rod but the bushings seemed to be fine and i could not figure out what it was hopefully this does the trick.....thank you :doh:
I think mine started up bad recently, I got to fix it, it's driving me nuts. I thought it was the shocks since I off road and bounce the front end a lot, but thinking this is more likely.
Wow, pretty sure this is what I was trying to talk about at the dealership at my 20K service and they heard nothing... they sprayed lube on the bushings though so they did something at least, haha
1 - 8 of 8 Posts
