Article No.
02-1-7
01/21/02
TRIM - DIP IN CENTER OF INSTRUMENT PANEL
FORD:
2001 ESCAPE
ISSUE
Some vehicles may exhibit a dip in the center of the Instrument Panel. This may be caused by the Instrument Panel having a low attachment point with the steel body bracket.
ACTION
Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Identify the dip condition (Figure 1).
1. Remove center attachment cover (Figure 2).
2. Remove center attachment bolt (Figure 3).
3. Remove radio (Figure 4).
4. Add/slide washer into place between the Instrument Panel and steel body bracket attachment (Figures 5 and 6). This will raise the instrument panel in the center.
NOTE
BASED ON SEVERITY OF I/P DIP, ADD SHIMS AS REQUIRED (NOT TO EXCEED 4 MM). PART NUMBER 9995 20800 IS 1.6 MM
THICK WASHER AND 9995 10818 IS 2.3 MM. THE WASHERS CAN BE COMBINED TO GET 3.9 MM.
5. Once spacer/washer is in place, reinstall radio, secure center attachment bolt, and replace top instrument panel attachment cover. Verify dip condition is corrected (Figure 7).
Parts Block
9995 20800 - Washer - 1.6 mm Thick - 3 Per Package
9995 10818 - Washer - 2.3 mm Thick - 10 Per Package
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION: 020107A
DESCRIPTION: Inspect And Install Spacer In Dash Center Support
TIME: 0.4 Hr.
DEALER CODING
BASIC PART NO.: 7804320
CONDITION CODE: 07
OASIS CODES: 107000
Article No.
02-1-7
01/21/02
FORD:
2001 ESCAPE
ISSUE
ACTION
SERVICE PROCEDURE
NOTE
Parts Block
OPERATION: 020107A
TIME: 0.4 Hr.
DEALER CODING
CONDITION CODE: 07
OASIS CODES: 107000
