This forum has been extremely helpful, so I decided I should post another problem I'm having. My hatch will sometimes unlock and other times it will not. I assume the motor is probably going out, but I'm not sure nor do I know how hard/expensive it would be to replace. I definitely can live without it, but if it's something I can do myself I'm up for it.
Anyone have any ideas?
Thanks in advance
A member called Walkingchaos has a replacement actuator for sale at the following post:
http://www.escape-city.com/viewtopic.php?f=21&t=5552&p=96695&hilit=actuator#p96695
You can check the following thread for additional info:
http://www.escape-city.com/viewtopic.php?f=8&t=4786&st=0&sk=t&sd=a&hilit=actuator
I'm not sure there is an "official writeup" or not but replacing the actuator has been discussed a few times and the above thread has a few links to other threads with advice.
Good luck getting it fixed up :peace:
Thank you for the information. Appears that actuators are not easy to find these days. A lot of 3rd parties that had them seem to be out.
Thank you for the links. I think I'll pull things apart and take a look.
