Dealer Letters
Attachment I - Administrative Information
OASIS
You must use OASIS to determine if a vehicle is eligible for this Special Service Instruction.
PLEASE NOTE:
Correct all vehicles in stock before delivery.
PROMPTLY CORRECT
Promptly correct all affected vehicles at your dealership and other eligible vehicles which are brought to your dealership within the applicable 36 month / 36,000 mile warranty coverage period.
CLAIMS PREPARATION AND SUBMISSION
^ Enter claims using DWE.
^ Refer to ACESII Manual for claims preparation and submission information.
NOTE:
Prepare and submit claims on the ACESII warranty screen rather than the ACESII recall screen.
^ Use code information shown below:
^ Program Code - 00T06
^ Causal Component - 4602
^ Condition Code - 12
^ Labor Operation - Refer to Attachment II
Attachment II - Labor and Parts Information
LABOR ALLOWANCES
PARTS REQUIREMENT
Parts Ordering Information
Parts will not be direct shipped for this recall. Order your parts requirement through the Recall Hotline (1-800-325-5621). Parts will be shipped Priority Next Day delivery, beginning the week of August 28, 2000 once sufficient quantities of parts are available at the PDC's.
NOTE:
Removed parts must be mutilated and properly scrapped to prevent their use on another vehicle.
ORDER INFORMATION DOR/COR
DOR/COR number 50175 identifies parts ordered for this campaign through the Recall Hotline (1-800-325-5621).
DEALER PRICE
For latest prices, refer to:
^ DOES II
^ Updated Price Book
EXCESS STOCK RETURN
Excess stock returned for credit must have been purchased from Ford Customer Service Division in accordance with Policy Procedure Bulletin 4000.
Attachment III - Technical Information
SERVICE PROCEDURE
CAUTION:
Do not reuse any driveshaft retaining fasteners. Install new fasteners only or damage to vehicle will occur.
1. Raise and support the vehicle.
2. Position a safety stand under the driveshaft center bearing support. See Figure 1.
3. Remove the bolts and straps securing the rear of the driveshaft to the differential yoke. Discard the bolts. See Figure 2.
4. Remove and discard the center bearing support nuts. See Figure 3.
5. Remove the center bearing support ground strap bolt from the floor pan. See Figure 3.
6. Remove and discard the bolts and washers securing the front of the driveshaft to the power take off. See Figure 4.
7. With the aid of an assistant, remove the driveshaft from the safety stand. Discard the driveshaft.
8. With the aid of an assistant, position the center bearing support of the new driveshaft onto the safety stand. Position the rear of the driveshaft into the differential yoke, then position the front of the driveshaft into the power take off.
CAUTION:
The rear of the driveshaft must be bolted to the differential yoke before the center bearing support nuts are installed.
9. Install the straps with new bolts to secure the rear of the driveshaft to the differential yoke. Tighten the bolts to 23 Nm (17 lb-ft).
10. Install new nuts to the center bearing support. Tighten the nuts to 48 Nm (35 lb-ft).
11. Install the center bearing support ground strap to the floor pan. Tighten the bolt to 40 Nm (30 lb-ft).
NOTE:
If front driveshaft bolts are missing or damaged, order Part Number YL8Z-4529-AA, quantity of one (1).
12. Install new bolts and washers to secure the front of the driveshaft to the power take off. Tighten the bolts to 37 Nm (27 lb-ft).
13. Remove the safety stand from under the center bearing support.
14. Lower the vehicle.
Special Service Instruction - Attachment I
OASIS
PLEASE NOTE:
PROMPTLY CORRECT
NOTE:
^ Causal Component-4602
MATERIAL ALLOWANCE
Special Service Instruction - Attachment II
LABOR ALLOWANCES
PARTS REQUIREMENTS
Parts will not be direct shipped for this recall. Order your parts requirement through the Recall Hotline (1-800-325-5621). Parts will be shipped Priority Next Day delivery.
NOTE:
DEALER PRICE
^ DOES II
EXCESS STOCK RETURN
Special Service Instruction - Attachment III
OVERVIEW
This program combines two procedures, a driveshaft replacement and a differential leak inspection/repair. These two procedures are closely related, and performing them together will save time.
DRIVESHAFT REPLACEMENT:
All affected vehicles will have a new driveshaft installed.
DIFFERENTIAL LEAK INSPECTION/REPAIR:
The mass damper is a weight bolted to the right side of the differential assembly. The damper may have been installed using the wrong tightening sequence. When installed incorrectly the damper does not contact all three mounting pads as the bolts are tightened. This creates a leak in the silicone seal between the rotary blade coupling housing and the differential housing. An inspection will be performed to identify leaking differential assemblies. If a leak is found, the coupling housing will be removed and resealed with silicone (F7TZ-1 9554-AA). The damper will be reinstalled using the correct tightening sequence.
INSPECTION
2. Wipe clean the seam between the rotary blade coupling and the differential housing. Check for fluid seepage at the seam. See Figure 1.
^ If no signs of fluid are found at the seam, perform Driveshaft Replacement only.
^ If signs of fluid are found at the seam, perform Driveshaft Replacement and Differential Reseal and Mass Damper Re-Installation.
CAUTION:
Do not reuse any driveshaft retaining fasteners. Install new fasteners only or damage to vehicle may occur.
1. Position a safety stand under the driveshaft center bearing support. See Figure 2.
2. Remove the bolts and straps securing the rear of the driveshaft to the differential yoke. Discard the bolts. See Figure 3.
3. Remove and discard the center bearing support nuts. See Figure 4.
4. Remove the center bearing support ground strap bolt from the floor pan. See Figure 4.
5. Remove and discard the bolts and washers securing the front of the driveshaft to the power take off. See Figure 5.
6. With the aid of an assistant, remove the driveshaft from the safety stand. Discard the driveshaft.
STOP
IF REQUIRED, PERFORM DIFFERENTIAL RESEAL AND MASS DAMPER RE-INSTALLATION NOW BEFORE INSTALLING THE NEW DRIVESHAFT.
7. With the aid of an assistant, position the center bearing support of the new driveshaft onto the safety stand. Position the rear of the driveshaft into the differential yoke, then position the front of the driveshaft into the power take off.
CAUTION:
8. Install the straps with new bolts to secure the rear of the driveshaft to the differential yoke. Tighten the bolts to 23 Nm (17 lb-ft).
9. Install new nuts to the center bearing support. Tighten the nuts to 48 Nm (35 lb-ft).
10. Install the center bearing support ground strap to the floor pan. Tighten the bolt to 40 Nm (30 lb-ft).
NOTE:
11. Install new bolts and washers to secure the front of the driveshaft to the power take off. Tighten the bolts to 37 Nm (27 lb-ft).
12. Remove the safety stand from under the center bearing support.
13. Lower the vehicle.
1. Disconnect the electrical connector from the rotary blade coupling.
2. Remove the mass damper. See Figure 6.
3. Position a drain pan under the differential assembly.
4. Remove the six bolts, then remove the rotary blade coupling. See Figure 7.
CAUTION:
Make sure the mating surfaces of the rotary blade coupling and the differential housing are clean and free of oil before applying silicone sealant. Do not use abrasive cleaning pads. The inside of the differential housing must be covered when cleaning to prevent debris from entering the differential.
5. Clean the gasket mating surfaces of the rotary blade coupling and the differential housing with Ford Metal Surface Cleaner (F4AZ-19A536-RA).
NOTE:
The rotary blade coupling must be installed within five (5) minutes of applying the silicone, or new silicone must be applied. If possible, allow one (1) hour before filling with lubricant to allow proper curing of the silicone.
6. Apply a continuous bead of silicone sealant (F7TZ-19554-AA) or equivalent to the mating surface of the rotary blade coupling. Make sure the bead covers 360 degrees around each bolt hole. Make sure the rubber wiring grommet does not touch or damage the new silicone bead.
NOTE:
The rubber wiring grommet must be guided into the slot on the differential housing during installation of the rotary blade coupling.
7. Install the rotary blade coupling. Tighten bolts to 32 Nm (24 lb-ft).
CAUTION:
The proper torque sequence must be followed when installing the mass damper. Improper sequence will create a leak at the seam between the differential housing and the rotary blade coupling.
CAUTION:
The initial torque for the damper rear bolt should NOT exceed 4 Nm (35 LB-INCHES).
8. Install the mass damper and finger tighten the bolts. Torque the damper as follows. See Figure 8.
^ Step 1: Torque rear damper bolt to 4 Nm (35 LB-INCHES) MAXIMUM.
^ Step 2: Torque front bottom damper bolt to 48 Nm (35 lb-ft).
^ Step 3: Torque front top damper bolt to 48 Nm (35 lb-ft).
^ Step 4: Torque rear bottom damper bolt to 48 Nm (35 lb-ft).
9. Connect the electrical connector to the rotary blade coupling.
10. Remove the fill plug from the differential cover.
11. Fill differential with approximately 2 pints of XY-80W90-QL rear axle lubricant. Fluid level should be between 6 mm (1/4 inch) and 14 mm (9/16 inch) from bottom of filler plug opening.
12. Tighten the fill plug to 27 Nm (20 lb-ft).
13. Return to Step No.7 to complete driveshaft installation procedure.
Dealer Letters
OASIS
PLEASE NOTE:
PROMPTLY CORRECT
NOTE:
LABOR ALLOWANCES
Operation Description | Labor Allowances | Labor Operation |
Replace Rear Driveshaft | 0.8 Hours | 00T06B |
Part Number | Quantity per Repair | Description |
YL8Z-4602-BH | 1 | Driveshaft, Rear |
YL8Z-4N272-AA | 4 | Bolt, Retainer (Sold 4 bolts to a package. One package will complete 1 vehicle) |
W705891-S301 | 2 | Nuts, Center Bearing Retaining (Sold 4 nuts to a package. One package will complete 2 vehicles) |
NOTE:
DEALER PRICE
^ DOES II
EXCESS STOCK RETURN
SERVICE PROCEDURE
CAUTION:
CAUTION:
NOTE:
OASIS
PLEASE NOTE:
PROMPTLY CORRECT
NOTE:
MATERIAL ALLOWANCE
Description | Part Number | Material Allowances |
RTV Sealant | F7TZ-19554-AA | Dealers may claim $6.56 per claim for the quantity of RTV Sealant used on each vehicle. To claim this allowance, use Miscellaneous Code "OTHER". |
LABOR ALLOWANCES
Inspect Rear Differential for Leak and Replace Rear Driveshaft | 0.8 Hours | 00T06B |
Inspect Rear Differential for Leak, Replace Rear Driveshaft, Reseal Rear Differential and Re-Torque Mass Damper | 1.2 Hours | 00T06C |
YL8Z-4N272-AA | 4 | Bolt, Retainer (Sold 4 bolts to a package. One package will complete 1 vehicle.) |
W705891-S301 | 2 | Nuts, Center Bearing Retaining (Sold 4 nuts to a package. One package will complete 2 vehicles.) |
F7TZ-19554-AA | Partial | RTV Sealant (One tube will complete 2 vehicles. Allowance of $ 6.56 per repair is provided.) |
XY80W90-QL | 1 quart | Gear Lube |
NOTE:
DEALER PRICE
^ DOES II
EXCESS STOCK RETURN
OVERVIEW
INSPECTION
CAUTION:
STOP
CAUTION:
NOTE:
CAUTION:
NOTE:
NOTE:
CAUTION:
CAUTION:
