Was told I need to replace my GEM module. Does it need to be programmed by the dealer Of can I just get one from a salvage yard? Does it need to be the same year and part number? Any Help is appreciated
You should be able to see your GEM asbuilt data subsystem then, you need to record the information off of it before you remove the module(YT how to swap GEM in 01 Tribby)Yeah I can read the codes
Have you tried pulling codes again?Go back to my original thread? No one had posted anything else for me to try otherwise I would have already done that. And as far as following direction I csn do that as long as someone gives me direction. And as far as your shop idea, ford didn’t know either
Have you tried a reset, by disconnecting the 12 V battery for a couple of minutes?Codes are still pretty much the same
My friend, I don't want to give you a hard time. I understand your frustration.And you still haven't gone back to your original thread.
You'll have to decide whether to follow directions and provide useful feed back or else just take it to a shop that knows what they're doing and pay them to fix it.
Good luck...
Did you by chance take a screenshot of the prev modules as-read information, to make sure it matches what you've uploaded?Yes I have but I will try doing all that again.
Be meticulous, check all the boxes doc ( :I didn’t take a picture but I uploaded a copy to my computer
