21 - 30 of 30 Posts
Swapping a module and copying data isn’t hard, could they problem be somewhere else
Sure, but stay on track… ( :
Diagnostically, you kind of have to go through everything based on what the system tells you
let's check all the boxes first, before you start looking elsewhere
ever heard the saying, garbage in, garbage out… I have found small errors that really put a big wrench in projects… Hindsight is always 20/20 Bruh ( :
B1318 means battery voltage to the GEM is too low. The GEM is doing what it's designed to do, save the battery, so the GEM turned everything off once the key was off. The GEM is working correctly. Test the battery and alternator. Charge the battery up overnight. Clear all codes. With Forscan, run KAM and then ROEO & KOER self-test. Battery must be fully charged and good. Alternator must be charging correctly for these tests to work.
KAM= keep alive memory. Erases all adaptive memory from PCM. Disconnection of the battery does the same thing.
KOEO= Key on, engine off. During this test, the PCM and other modules, like the GEM, will run a list of internal self tests. The horn will honk, the cooling fans will come on, etc.
KOER= Key on, engine running. This test is run with the engine running. Again, self tests.
Sometimes these self-tests must be run so the BCM/GEM will unlock themselves and start working.
Font Rectangle Screenshot Parallel Number
21 - 30 of 30 Posts
