First Post!
My wife has a 2002 Escape XLT 4WD. Noise coming from the front end while turning.
I put it on jack stands and found a slight knock in the left cv joint/half shaft on the transmission
end when turning the wheel by hand.
The right side does NOT make this noise. Is this cause enough to replace the CV joint?
I don't want to waste money changing the cv joint if this noise is normal in other Escapes.
Any answers are greatly appreciated.
