TSB 06-4-9
03/06/06
A/C COMPRESSOR NOT OPERATIONAL / LOW FREON-SHAFT SEAL LEAKS
FORD:
2003 Escort
2003-2006 Focus, Mustang, Taurus
2003 Explorer Sport, Windstar
2003-2005 Excursion, Explorer Sport Trac
2003-2006 Escape, F-150, F-Super Duty, Ranger
2004-2006 Freestar
2006 Low Cab Forward
LINCOLN:
2002 Blackwood
2006 Mark LT
MERCURY:
2003-2005 Sable
2004-2006 Monterey
2005-2006 Mariner
ISSUE
Some 2002-2006 vehicles equipped with an FS-10 A/C compressor may experience a non operational A/C compressor due to a low freon level caused by a leaking shaft seal.
ACTION
Replace the A/C compressor shaft seal following the Service Procedure.
SERVICE PROCEDURE
If the shaft seal on the front of the A/C compressor is leaking, replace the shaft seal (F1VY-19D665-A) and not the compressor assembly. Replacing the shaft seal should correct the leaking condition. When replacing the seal, follow the procedure outlined in Workshop Manual, Section 412-03.
F1VY-19D665-A - A/C Compressor Seal Kit
OPERATION: MT060409
DESCRIPTION: Use Standard Labor Operation For Compressor Removal And Installation If Available, And Claim Additional Labor Required As Actual Time
TIME: Actual Time
DEALER CODING
BASIC PART NO.: 19D665
CONDITION CODE: 42
03/06/06
FORD:
2003 Escort
2004-2006 Freestar
LINCOLN:
2002 Blackwood
2006 Mark LT
MERCURY:
2003-2005 Sable
2004-2006 Monterey
2005-2006 Mariner
ISSUE
ACTION
SERVICE PROCEDURE
OPERATION: MT060409
TIME: Actual Time
DEALER CODING
CONDITION CODE: 42
