1 - 16 of 16 Posts
My 2004 ford escape, 3.0 V6 engine, has recently started chugging when the weather is very wet, and the check engine light will blink. When the weather dries up, the problem and the light go away. I recently replaced the spark plugs, and inspected the coils.
The issue is only occurring in wet weather, in dry weather, it runs beautifully, smooth and crisp, idles smooth. In older vehicles I have owned, this problem was usually solved by replacing the distributor cap and rotor, but I have the coil on plug system, so I am not sure what the comparable components would be.
Does anyone have any advice on this issue, or experience with the same problem? Thank you very much for any help.
I would rule out the coils first thing. Get a spray bottle, and mist the coils with water in a dark area with the car running. If it starts running rough, or you see sparks, then you've got some sort of small crack in the coil that is causing a voltage leak.
It definitely sounds like an electrical issue though - does it act up at idle, or only when you're driving it?
The issue will happen while idling and driving, but only when the weather is rainy. I would like to rule out the coils, or at least be able to test them, as they are $50 to $80 each. Research on the internet definitely shows this is a common issue, but there doesn't seem to be any clear cut solutions out there. Thanks for the reply.
Do you mean solutions for testing the coils? I gave one in my previous post.
Does it run rough when it's rainy AND the truck was just started and idling? Meaning it hasn't been driven yet.
Or does it run rough while idling AFTER it's been driven while it's rainy?
While the first thing I'd go for is moisture on the COPs, they're sitting on top of the engine. An idling vehicle that hasn't moved "should" have a hard time getting moisture on the COPs unless it's coming down from the hood or somehow a leak from the cowl.
Just trying to eliminate things.
Other culprits could be moisture on the wiring harness on the CKPS and/or CPS. But again, you're unlikely to get water on these if the vehicle is stationary.
Just the same, I would inspect the COPs and put a dab dielectric grease on them. Same with the CPS and CKPS connectors.
Just my 2 cents.
Thanks slavrenz and Four_Eyes. I definitely have to carefully inspect all these components. I never heard of dielectric grease, but I will pick some up. Misting the coils will definitely work on cylinders 4-5-6, but I cannot do that for 1-2-3, b/c I have to remove the intake manifold to access those three, what a pain in the ***. Anyway, I will have to get in there and check as much out as I can see. Thanks again. By the way, what is the comparable part to a distributor cap and rotor, is it the ignition coil terminal that all the wires go to?
leodajim said:
Thanks slavrenz and Four_Eyes. I definitely have to carefully inspect all these components. I never heard of dielectric grease, but I will pick some up. Misting the coils will definitely work on cylinders 4-5-6, but I cannot do that for 1-2-3, b/c I have to remove the intake manifold to access those three, what a pain in the a**. Anyway, I will have to get in there and check as much out as I can see. Thanks again. By the way, what is the comparable part to a distributor cap and rotor, is it the ignition coil terminal that all the wires go to?
Dielectric grease is used on battery terminals, spark plug boots, and electrical connectors to keep out moisture and corrosion. It's also just called "spark plug grease", and several other names as well - it's good stuff to have.
I'm not sure I understand your question about the ignition system. I don't know the earlier Escapes too well, so is it a waste spark setup (i.e., one coil for two plugs), or does it have a coil for each plug?
Its a coil for each plug, with the electrical connectors/wires coming off of each coil. I am assuming that all the wires go to a central component, and that component would be the equivalent of a distributor cap in older vehicles. I think it is called the ignition coil terminal, but I am not sure. I am wondering if perhaps moisture is affecting that terminal, and causing misfire codes.
Nope. The spark itself is generated at the coil - the wires just lead back to the Engine Computer, or PCM, which tells each coil when to fire.
OK, gotcha. So it is pretty safe to say that the issue is not occurring with the PCM. So now I understand the end points of the system, and most likely my issue is occurring somewhere between those two points. I picked up some dielectric grease and will apply that where necessary.
Thanks for the education. Merry Christmas.
I used to have this problem. It is usually the front cylinders that this affects. cylinder 4 and 5 are the most common. An Autozone or autoparts store can read the computer code and give you the misfiring cylinder #. I would purchase a OEM set on ebay. I bought all 6 for under 100 shipped.
Interesting, as 4 and 5 are exactly which ones were coding for me, and from research on the internet, for so many other people as well. I have replaced the spark plugs in 4-5-6 for now, and I will do replace 1-2-3 when I have time to take off the intake manifold. I am also going to purchase the set of coils and replace 4-5-6 right now, and then 1-2-3 when I do the plugs.
Thanks for the post. I feel more confident that doing this work will solve my issue. If the issue of bad tuning went on long enough, I would risk destroying a cat converter(s).
Discussion Starter · #14 ·
If your misfires are kicking a code, have the code checked and it should tell you which cylinder is misfiring. Anytime I have had this issue since these posts, it has been a spark plug. The coils seem to hold up pretty well, but they do go bad from time to time.
Hello, leodajim -
Thanks for your note. This problem has accumulated some history since it became an issue in March when I contacted you. I'll try to summarize....
Current status: My 2005 Tribute with 3.0 V6 Engine is running smoothly, although there has not yet been wet weather to confirm the fix. DTCs are now down to a single code and are different from the initial misfire codes. However, some questions remain.
Steps taken:
1. Changed plugs: I bought Motorcraft AGSF 32 plugs (later I found out these were probably wrong) at the autoparts store, per the recommended application in the store computer. I replaced the existing plugs that had around 60k miles on them. The old plugs did not look particularly bad, although some carbon was accumulating. The gaps were all within specs.
While this seemed to remedy the misfire on cold start-up problem for about a week, the problem returned and was much worse when eventually the weather turned wet and cold. When I came home after driving 100 miles in rain, the engine was barely running. AutoZone scanned my OBD and came up with the following DTC codes: P0352, P0354, P0355, B2900, U1900, C1805.
2. PCM diagnosed:
- I bought a code scanner and found the above B, U, and C codes were no longer occurring. Some of the misfiring moved to other cylinders. I checked all the plugs for ignition from the PCM and found no spark on several of them. Verifying continuity between the coil terminals and the PCM connectors, I reasoned the problem must be in the PCM.
- I found some Mazda service bulletins related to the misfire problems on 2005-6 models, with the last written in October, 2010: 01-50/10 (btw, BBB Industries has a great service - full text TSBs for free! at http://www.bbbind.com/free_tsb.html).
Although I have a healthy skepticism when it comes to manufacturer recommendations for wholesale change-out of expensive parts (their incentive is more often CYA and profit-related than recommending what's best for their customers), the TSB did seem to fit my situation: "MIL with multiple Primary Circuit DTCs P0351, 352, 353, 354…. " Unfortunately, the fix recommended in the TSB was replacement of the PCM as well as all plugs and Coils on Plugs. Mazda dealer quoted $1335 for the PCM, and around $800 for the plugs and COPs, totaling around $2,200. Aftermarket sources wanted around $450 for the PCM.
3. PCM, COPs and (newly installed) plugs replaced:
- Mazda COP = AJ09-18-100 specified in the TSB crosses to Motorcraft 1L8Z12029AB, which has since been updated to 2M2Z-12029-AC.
- Dealer recommended Motorcraft plug was AGSF32WM1.
- I found a company in South Carolina (Circuit Board Medics) with a well earned BBB rating of A+ that would either repair my PCM ($300) or send me a replacement in exchange for my core ($350). Circuit Board Medics also had an arrangement with Auto Nation Ford dealership in Minnesota for a discounted price for the COPs and plugs for their customers who were getting their PCMs fixed. Circuit Board Medics explicitly required replacement of the COPs before installing the refurbished PCM in order for the warranty to be valid. My total cost for board repair and all ignition parts was about $700.
- The Ford parts people said that the Motorcraft AGSF 32 plugs the local parts store had sold me were for a Taurus and not particularly recommended for Escapes or Tributes. Given the TSB reported COP damage due RFI from mis-matched plugs, I decided not to take a chance and so purchased the AGSF32WM1 plugs.
4. More problems: Oxy Sensor and Cam Position DTCs. Engine stalled and would not crank.
- After installing the ignition related parts and going through the key-reprogramming procedure, the engine started. It ran rough at first due to EGR gasket and PCV line not being seated properly (my goofs). These problems were quickly identified and remedied and the engine ran smoothly briefly.
- Then the MIL came on and OBD listed the following codes: P0135, P0141, P0155, P0161, P0171, P0174, P0340 (oxy sensors and Cam Position Sensor malfunctions).
- After the engine ran smoothly for 10 or 15 min, I decided to take the Tribute for a test drive, codes and all. But before I got out of the garage, the engine quit and would not crank. The dash lights stayed on with the key out of the ignition. They turned off only when I disconnected the battery. When I reconnected it, the dash lights stayed off with the key back in until I moved the switch to RUN. Then they came back on again and the starter still would not crank. Again, the dash lights still would not go out until I disconnected the battery. With the battery connected and dash lights on, the code scanner reported it could not establish a link, so I had no diagnostic codes to guide me.
5. Replacement PCM was OK.
- Since the scanner was unable to communicate with the PCM, I assumed the replacement PCM had more problems than had been fixed and was likely responsible for the newly logged DTCs. After discussing my situation with Circuit Board Medics, I returned the replacement PCM to their repair shop along with my core. They reported No Fault Found and said it worked perfectly when they checked it by installing it in their test vehicle. I asked them to repair my original PCM and send it back to me, which they did, after verifying that after repair it worked properly in their test vehicle.
- After installing my repaired PCM and going through the key validation sequence, the Tribute still had the dash lights on/ no crank problem.
6. Few clues: OBD still not communicating with scanner.
- After ruling out the PCM, I had many suspects but few leads: PATS anti-theft immobilization issue? Bad grounds? Blown fuses or bad relays? Wires or components melted from catalytic overheating? (but no real evidence of actual overheating), Alternator failure? Cam Position Sensor failure? The OBD system still was not talking to my scanner.
- I spent several days gathering circuit diagrams (Autozone has posted many of the Tribute wiring diagrams on their web site) and information on the iPATS system. I looked for reports of similar symptoms on the internet, and tried to learn how all the pieces fit together.
- Using the wiring diagrams, I eventually traced the dash lights-on-with-key-out condition to the cooling fan circuits which were keeping the PCM relay energized. I also cleaned up the battery terminals, replaced several of the relays on principle (only 1 acted questionably), and cleaned up several harness ground points.
- When I took the 3 cooling fan relays (which had all tested good) out of the Battery Junction Box, the dash lights behaved normally and the Tribute started and ran smoothly, and the PCM talked to the scanner. When I disconnected the fans and replaced the relays, it again started and ran smoothly, with no sign of the lingering dash lights.
7. Back to the Present: Running well, but not sure why.
- Unfortunately, when I reconnected the fans, the Tribute started and idled well, other than a lingering P0141 trouble code. It warmed up to the point of running the fans. I wrote "unfortunately" because now I do not have a root cause to point to. I cannot say what might have caused or what "fixed" the dash lights-on-with-key-out condition.
Here are some final thoughts (though no firm conclusions) on what I discovered through my efforts:
- The original PCM was likely damaged during my 100 mile trip in the rain. (Though I have not discussed the repair findings on my original core with the PCM repair shop.)
- I've read one or two accounts of Tributes with the misfire problem being repaired and running well for a few days and then the problem recurring. I believe the misfire problem has been addressed in the case of my Tribute as well as possible and think (hope) it will not recur.
- The larger uncertainty has to do with the dash lights-on-with-key-out/no-start condition. Although I changed out some relays and cleaned and tightened a number of grounds, I'm not sure the root problem has been fixed or that it will not reappear.
- The remaining oxygen sensor DTC P0141 may be the result of damage during the drive in the rain. My next step will be to get under the car and physically check out the wires and sensor. This seems like a more manageable problem than the misfire and the dash light/no-start condition.
If you're interested in any further details, I'll be glad to provide them.
2004 Ford Escape XLT
Thank you. I have many unsolved electrical glitches in my Ford Escape 2004 XLT. Weird stuff that throws no codes, like my blinkers cadence changing or my radio volume going up and down by itself. This only happens in high humidity. (I've got Multiple Sclerosis and the same stuff happens to me in humidity. lol.)
Right now I've got the P0141 code so I'm very interested in hearing more of your story.
Hopefully you'll solve my problem for me.
1 - 16 of 16 Posts
