IDLE AIR CONTROL (IAC) VALVE
Removal and Installation
_Valve/iac_.png)
_Valve/iac_.png)
- Disconnect the battery ground cable.
[/*] - Remove the 3 screws, the pin-type retainer and the upper and lower snow shield.
- To install, tighten to 10 Nm (89 lb-in).[/*]
- Disconnect the idle air control (IAC) valve electrical connector.
[/*] - Remove the 2 bolts and the IAC valve.
- To install, tighten to 4 Nm (35 lb-in).[/*]
- Inspect the gasket and install new as necessary.[/*]
- To install, reverse the removal procedure.[/*]
