Intake Manifold
Removal and Installation
- With vehicle in NEUTRAL, position it on a hoist.
[/*] - Remove the throttle body.
[/*] - Remove the fuel rail.
[/*] - Remove the oil level indicator and tube.
[/*] - Disconnect the intake manifold vacuum hose and pin-type retainer.
- Position the vacuum hose aside.[/*]
- Disconnect the power brake booster vacuum tube
- Depress the quick release locking ring.[/*]
- Pull the vacuum tube out of the quick release fitting.[/*]
- Disconnect the fuel vapor return hose from the intake manifold.
[/*] - Disconnect the idle air control (IAC) motor electrical connector.
[/*] - Disconnect the swirl control valve electrical connector.
[/*] - Disconnect the knock sensor (KS) electrical connector.
- Detach the electrical connector pin-type retainer.[/*]
- Disconnect the temperature manifold absolute pressure (TMAP) sensor electrical connector.
[/*] - Disconnect the oil pressure sender electrical connector.
- Detach the wiring harness pin-type retainer and position the wiring harness aside.[/*]
- NOTE: There are 3 different size bolts used. Mark the location of the bolts to make sure they are installed in the correct location.
Remove the 8 bolts and position the intake manifold aside to access the crankcase vent hose clamp and the EGR tube.- To install, tighten to 18 Nm (13 ft. lbs.).[/*]
- Release the clamp and disconnect the crankcase vent hose.
[/*] - Remove the exhaust gas recirculation tube.
- To install, tighten to 55 Nm (41 ft. lbs.).[/*]
- Remove the intake manifold and gaskets.
[/*] - To install, reverse the removal procedure.
- Inspect and install new intake manifold gaskets if necessary.[/*]
